Do the 14's Have the "Bagger Wobble"
Old Jan 16, 2015 | 02:55 PM
  #41
Kcdcltd's Avatar
Kcdcltd
Never a hint of front end wobble no matter how hard I have pushed my 2014 Limited. She will wiggle her hips a little if pushed very hard thru high speed sweepers but nothing alarming. Front end very secure.
Old Jan 16, 2015 | 04:04 PM
  #42
yowflhtk's Avatar
yowflhtk
Originally Posted by 2black1s
And the counterpoint thought... Why would anyone want to putt around like an old grandma all day long? Where's the fun and excitement in that?
And to add my two-cents to the original question... I'm not sure how the 14s handle but I imagine the front end changes can do nothing but help. As for '08 and earlier models, I don't know because I never rode one. The '09 through '13 models, of which I have an '11, do exhibit some wobble under the right conditions but nothing near what I would call a "death wobble" and I think that tires are a major influence. Any wobble with my bike is nearly non-existent when the tires are new, but the wobble becomes more regular, more pronounced, and expected as the tires get some miles on them.
Exactly what he said above. My 11TK has done it as well.
.......martin
Old Jan 16, 2015 | 04:07 PM
  #43
yowflhtk's Avatar
yowflhtk
Originally Posted by skratch
most of the people that i've heard that experienced the wobble was not in riding the twisties aggressivley. it was on those long sweepers on the interstate at high speed.
myself, i had it happen twice on my 07. both times were at higher speed on the highway. scared the chit outta me never had it on any of my other bikes.
Same observation on my 11 FLHTK.
.........martin
Old Jan 16, 2015 | 06:29 PM
  #44
BLKPRLFLHTCU's Avatar
BLKPRLFLHTCU
I experienced a slight wobble once on my 07, after a good look over many miles later I found there was a small oil leek on one on the rear shocks. (stock ones) I replaced the pair with a new set someone removed to lower their bike and I have never had a problem since.
Old Jan 16, 2015 | 06:44 PM
  #45
roadking2014's Avatar
roadking2014
Originally Posted by Freebirdsride1
One of my new tour bike driver has a 09 with front end wobble. He was pulling back on the handlebars instead of pushing on them. Adjusted the handlebars to fit him and the problem went away. My 08 has rubber role when I,m hot I the corners.
exactly right. I had a tank slapper when I was speeding through sweeping turn on an 08 road king I had. I thought about it later and thats what I was doing, pulling back on the bars as I was going ***** out trying to outrun a friend instead of pressing against em.
Old Jan 16, 2015 | 07:39 PM
  #46
Webo's Avatar
Webo
I've had mine wobble a bit on long sweeping corners at high speed when the pavement is not perfectly smooth. I went into one at about 85mph and hit a small imperfection and the back started to wobble. I just let off the throttle and rode it thrust the corner and then hammered down on it. Its going to happen from time to time when your pushing the limits.
Old Jan 16, 2015 | 10:28 PM
  #47
Cruisineasy1's Avatar
Cruisineasy1
My '14 SG up to 95. No wobble so far
Old Jan 17, 2015 | 09:23 PM
  #48
Lowcountry Joe's Avatar
Lowcountry Joe
Straight line speed has nothing to do with this discussion.
It's the long sweepers such as on the interstate or multi-lane primary roads where you enter them at 80 or above and maintain those speeds (or greater) through the duration of the curve. That's where it happens if it happens at all. The oscillations must have time to build, and that is exactly what happens in the very long sweepers. Quick twisties will not exhibit the same problem. You may feel a wiggly back end, but that's your fault for not managing available friction.
The larger cross-sectional area of the Rushmore front legs and the front clamping improvements should help to minimize the buildup and amplitude of the oscillations, but I am afraid not totally eliminate these oscillations depending upon the duration of the high-speed curve undertaken.
With the continued use of cheap air shocks and motor mounting, even on the Rushmores, a good set of high quality rear shocks and high quality motor to frame stabilizer, such as a True Track, would add even more oscillation dampening.
Light sport bikes are made for high speed sweepers, not 800 lb Harley touring bikes.
JakeyL.
Oct 19, 2014 10:49 PM
DarkMatter
Jul 5, 2014 08:49 PM
dobro
Jul 7, 2013 11:10 AM
petenpole
EVO
Dec 15, 2011 02:44 AM
PirateRider
Aug 5, 2010 10:00 AM
