torque specs.
Old Dec 5, 2013 | 09:00 AM
hardheaded's Avatar
hardheaded
well i guess you have to go with what the factory is saying, 140 lbs. final torque.
Old Dec 5, 2013 | 09:42 AM
Nute's Avatar
Nute
Not a good idea to use an Impact Wrench on the Compensator Bolt as the pulses from the impact have been known to knock the magnets in the stator off causing failure of your altenator.
Old Dec 5, 2013 | 10:09 AM
hardheaded's Avatar
hardheaded
can't believe there isn't any techs on here that wrench everyday that would know for a fact what the spec. is
Old Dec 5, 2013 | 10:12 AM
soft 02's Avatar
soft 02
Just split the difference and torque it to 150 ft lbs.
Old Aug 24, 2019 | 05:19 PM
DIESEL-FUMES's Avatar
DIESEL-FUMES
I did mine last night.. said to go to 100. Then to back off one complete turn and then torque to 140. I did 140. However, I put a lot more than a couple drops of red thread locker on it. I had an 06 heritage that I only put a couple drops on. The compensator came loose in one season. Thankfully while I was pulling into my shop after along ride...
Old Feb 15, 2024 | 04:09 PM
Evohead93's Avatar
Evohead93
Stage I
Originally Posted by Guntoter
Oh no you dint! I can hear the screams of the **** retentive and torque obsessed members now............
nope, that's gonna loosen up fast..I did 165ft lbs
Old Feb 15, 2024 | 04:43 PM
hattitude's Avatar
hattitude
Originally Posted by hardheaded
well, i called the factory today and after much looking and asking other techs i was told the torque in the service manual is correct at 140 lbs. final torque. they knew of no update of torque specs. for the 2012 bikes using the screaming eagle comp. that came stock on them.
Short answer:
Hardheaded, if you are installing your 2012 OEM comp with the 9/16 hex head comp bolt, your final torque is 140 ft lbs. If you are installing the SE Big Twin Comp kit (which retro fits the newest comp to your 2012 bike) with the Torx (I believe it's a T70) comp bolt, your final torque is 175 ft lbs.
Long answer:
The 2012 OEM comp, was the first SE comp that became OEM... it uses a #3368 9/16-1/2 x 3 Hex Head screw. The final torque spec on that comp & screw combination is 140 ft lbs.
With the Rushmore bikes in 2014, the comp was upgraded again. The newest version needs the scoop in the outer primary cover to direct oil to the comp bolt. With the introduction of that newer comp, it's retrofit kit then became the second version of a Screamin' Eagle Big Twin Comp.
This newest OEM comp & the second SE Big Twin Comp (retrofit kit for older than 2014 Twin Cams) is different. It uses a tapered Torx head bolt #10500031. The newest Twin Cam comp version (OEM or SE retrofit kit) with the Torx head comp bolt has a final torque spec of 175 ft lbs
I just confirmed the comp bolts' part numbers and final torque specs in my 2012 & 2016 Factory Touring Service manuals and Factory Touring parts catalogs.
I hope this info helps...
Old Feb 15, 2024 | 09:20 PM
MotoJockey's Avatar
MotoJockey
Hat........... I gotta admit, I love reading your very detailed and thorough posts. Seriously............. Even if it is on a 10+ year old thread, you're always spot on sir!
Old Feb 16, 2024 | 08:39 AM
hattitude's Avatar
hattitude
Damn it...... I got bit by an old thread......
For some reason I didn't even notice the date of the thread...... I usually don't even open them...
F-ing Hostile
Air Suspensions
Sep 10, 2012 01:52 PM
bagman1
Sep 9, 2012 05:38 PM
HOG_0308
Jul 18, 2010 11:01 PM
straydog13
Ironhead
Aug 3, 2008 12:47 AM
ScooterGuitar
May 16, 2006 12:30 AM
