I couldn't seem to find the exact answer to my questions in the various threads.
I am going to pull the trigger on the Phase 7 and passing lamp kit from discount Fleet Supply.
Does the 2013 EG Ultra Classic need the H4 to H13 adapter?
Do you need any sort of trim ring for the phase 7 series?
I have the mod (relocated the two wires in the connector) to keep my passing lamps on w/ hi beams. Any issues continuing?
You need one of the Harley French trim rings due to the fact that the light sticks out a bit from the lamp housing. You may not need it but IMO its a must. I don't know about any adapter's for the 13's but my 12 Street Glide was plug n play.
Does the 2013 EG Ultra Classic need the H4 to H13 adapter? No
Do you need any sort of trim ring for the phase 7 series? Yes, if you want it to look "decent." I have the mod (relocated the two wires in the connector) to keep my passing lamps on w/ hi beams. Any issues continuing? No, which mod ($pendy HD part, splice wires, or swap in harness?
Eastern has the best buy right now..look at the other thread and it will give you the link for EP link to their ebay site...its a great deal
Is that a 2014? If so what ring did you use? Pt# please
Sorry no that is a 2012. Part number on this one is #69627-99.
This is the 2014 models it will fit
Switchback FLD
Heritage Softail Classic FLSTC
Fat Boy FLSTF
Fat Boy Lo FLSTFB
Softail Deluxe FLSTN
CVO Softail Deluxe FLSTNSE
Road King FLHR
CVO Road King FLHRSE6
