winter storage - no tender
Old Dec 20, 2013 | 09:36 PM
texaswiz's Avatar
texaswiz
Originally Posted by Hammz
Throw it away & buy a new one in the spring. Seriously, pull the battery & put it on a BT at home.
What he said.
Old Dec 20, 2013 | 10:18 PM
Bill03E's Avatar
Bill03E
My dealer stores bikes on a tender, does an oil change, and washes it before you pick it up for $200.00 they store them under cover too.
Yep take it out and store it at home on a tender. The battery will last years longer if you do. And you won't be here in a year with a gripe about HD batteries not lasting.
ECM will not lose it's programing .
Just take it out and put it back in the right way so you do not short anything
Pull main fuse.
Disconnect ground first
When you put it back connect Positive first.
Then replace main fuse.
Next year store it at HD for a dollar a day or less they keep it warm and on a tender.
Heck dealers here even pick up and drop off free.
Old Dec 21, 2013 | 12:30 AM
Birdman2778's Avatar
Birdman2778
My dealer has a similar deal as stated above.
However, after a gasoline tanker overturned and almost burned the dealership down, my RK is much safer in my garage with no electric.
Old Dec 21, 2013 | 04:29 AM
WILDWOOD_1124's Avatar
WILDWOOD_1124
Now that's a good deal!
Old Dec 21, 2013 | 04:54 AM
dswansbiker's Avatar
dswansbiker
If your bike doesn't have the security system there is no electrical drain and the battery will hold up just fine over a few months. If it has security, disable it.
Old Dec 21, 2013 | 06:48 AM
RK_2014's Avatar
RK_2014
Great idea - not near the manual - I assume instructions for disabling are in it?
Old Dec 21, 2013 | 06:54 AM
SafetyMan's Avatar
SafetyMan
Originally Posted by rnl_1200C
Give it to me straight - whats the expected damage to the battery ??
I would take the battery out and put it on a tender at home.
Since you're afraid to put your location, or even your state, in your information I can't tell you how much the temps will hurt your battery.
Next time look for a facility with power.
Old Dec 21, 2013 | 07:09 AM
dswansbiker
Yes, and I am not 100% on this but there should also be a fuse that can be pulled.
Old Dec 21, 2013 | 07:31 AM
grbrown's Avatar
grbrown
I'll just add my vote for removing the battery and taking it home to keep on a tender. If Father Christmas is short of ideas for you, he just got a prompt!
Old Dec 21, 2013 | 08:06 AM
dswansbiker
None, if you disable the security system (if you have it).
