What's the secret?
Old Dec 23, 2013 | 12:07 AM
Turret_plug's Avatar
Turret_plug
Sucked a military bootlace through with a shop vac..... Pulled the TBW AND right side wiring at the same time...... I did clip and solder the green clip out of the way.
Old Dec 23, 2013 | 07:16 AM
bcane98's Avatar
bcane98
I got thinking last night do I pull both through, many of you answered that, did y'all pull both cables together or one at a time? I see a couple of you pulled them both through at the same time. I've been using twine from Lowes and dish soap as my lube. Only a couple pieces broke, but the is to due multiple pulls and rubbing the exit point. My daughter has been helping me with this and I must say she has been a real champ about it too... she helps me remain calm :P
I'm gonna give the green clip one more try, if it doesn't make it through this time it's gone.
Old Dec 23, 2013 | 08:05 AM
btsom's Avatar
btsom
Bars with sharp corners rather than bent curves may lose favor with tbw. I had no trouble with the bent curve style.
Old Dec 23, 2013 | 09:01 AM
damquick1's Avatar
damquick1
string trimmer line and cocoa butter as a lube....did my buddies bars with it...plug left on and pulled right through....take your time...you'll get it
Old Dec 23, 2013 | 09:11 AM
crimson13's Avatar
crimson13
I would cut the green plug solder and shrink tube it or get the se tbw , the green plug is fragile and will pull apart in the bars.
Old Dec 23, 2013 | 10:33 AM
vickers1's Avatar
vickers1
Cutting the green connector is not a problem and very necessary. Get a roll of weedeater line and fish it through to the bottom hole. Tape approx. 3 or 4 wires to it and fish them past the bend. Then tape 3 or 4 more and fish them past the bend. Keep doing this and as wires come thru the bottom, cut them loose from the weedeater line.
Time consuming but easy.
Old Dec 24, 2013 | 04:26 AM
skipperhd1's Avatar
skipperhd1
Cool ape hangers
now i know why my buddy had the shop do it for him! cheers from montana
Old Dec 24, 2013 | 06:40 AM
09 YELLOWBIRD's Avatar
09 YELLOWBIRD
Just put some new bars on two weeks ago.
Good advise already posted. This one works and is Pretty EASY.
Got it one the first run, for both sets of wires for TBW, Heat Demons Heated grip wires.
AIR COMPRESSOR AND SMALL STRING.
Happy Holidays to all!
YB
Old Dec 24, 2013 | 07:35 AM
biil9's Avatar
biil9
Originally Posted by Gruamach
Patience.
High-strength fishing line to use a pullers
Patience.
KY/vasiline....coat the harness with some of it to help it slide down the tube & around corners.
More patience.........
Oh, needle-nose pliers to pull apart the plug ends.
And make sure you label the wires so you put them back together in the right order.
Oh, and lots of patience.
beautiful bike sir
Old Dec 24, 2013 | 08:05 AM
FenderGuy53's Avatar
FenderGuy53
Originally Posted by SBates08
I cut out the green plug as well but there are some on here who don't condone it.
Cutting out the green plug is not recommended because: 1) there is built-in resistance in the wiring, AND 2) doing so makes it much easier to lose track of what wire goes where! You may get away with it if you cut the wires as close to the switch as possible, and you pay very close attention to the wiring, but it's not recommended.
You could also buy the SE TBW for $100 and it has no green plug. Vaseline works wonders on wire pulling.
This is the preferred method, and the method that I used. I picked up a SE throttle sensor kit on Ebay for $50!
big papa AZ
Apr 27, 2018 08:30 PM
Mdb8223
Jul 7, 2017 10:51 AM
sharpshooter
Jun 15, 2017 06:59 AM
Powertrip240
2014-2024 Touring Models
27
Mar 16, 2016 07:38 PM
wam6187
General Topics/Tech Tips
Mar 8, 2016 06:54 PM
