Winterizing
Old Jan 5, 2014 | 07:55 PM
Ron750's Avatar
Ron750
I don't put anything under my bike. The reason people do it is to limit moisture from the ground/cement from condensing on your bike causing rust. I stored my bike in a new storage unit with no cement in unheated WI and didn't have any rust. I do put steel wool in my exhaust to keep mice out, run Stabil for 10 minutes in a full tank of Premium nonethanol gas. I usually change the oil but only had 800 miles on my Mobil 1 so I didn't.
howitzer88's Avatar
howitzer88
Originally Posted by Geezr Glidr
To tell you the truth, I don't know why I put cardboard under the tires. Just because somebody told me I should, one time, I guess! Sure, go with carpet remnants. Might even be better than cardboard. Who knows?!!!!!!
The alkali in concrete causes dry rot, as will moisture.
Old Jan 5, 2014 | 08:18 PM
Mike23's Avatar
Mike23
4th Gear
Originally Posted by Turret_plug
I'm sure it been beaten to death here, but...... Do any of you guys winterize? I'm in Kansas,many winter is certainly here. In the past I've just topped off, stabilized the fuel and ran her for a bit every now and then, and shifted through 1st and 2nd and rolled it a few feet in the garage to keep the primary and trans fluid moving a little. I also kept the tender plugged in.
On my ATV and dirt bikes in the past, we just topped off, stabilized, ran some fogging oil in the intake and waited till spring. I've never winterized any of my Harley's, but I'm new to this kind of winter with them (Army has always kept me in warmer climates)
What's the consensus?
The only thing i do different is not start the bike unless i can ride it until the oil is fully warmed up. I'm told starting and stopping during the winter causes condensation .Best to leave it on the tender till your ready to ride it
Old Jan 5, 2014 | 09:18 PM
Turret_plug's Avatar
Turret_plug
All good advice, I appreciate it!
Old Jan 6, 2014 | 01:13 PM
Ghosteh's Avatar
Ghosteh
I use fuel stabilizer, full tank of gas, let it run a bit to circulate, fresh oil change, check the other fluids, clean the bike & give it a really good coat of wax, remove the battery & seat (just because I have it off & have room inside) and take them indoors for the winter. I'll roll it occasionally so the tires don't develop flat spots. (Never did the cardboard thing, and I'm wondering if that would help. Probably won't hurt.)
Normally I don't remove the battery, but it's damn cold out this week, and I just bought the thing in Sept & would rather it not go bad on me.
In the past, I've left it on a lift, but the hydraulic cylinder leaked down. No damage, but I don't want to risk it falling over. What I need is a nice metal "bike rack" to lift it up & take the weight off the tires.
Oh yeah... and I cover it.
Probably it's overkill, but I enjoy taking care of it & for 30 years have never had an issue with storing bikes that way.
Old Jan 6, 2014 | 07:04 PM
Johan96's Avatar
Johan96
Do not use cardbord, better with an oversized guiness bar mat ;-)
Old Jan 6, 2014 | 07:50 PM
'05Train's Avatar
'05Train
It's overkill. Tires haven't flat-spotted in decades, batteries are fine on tenders, and the oil is fine. Fuel stabilizer is fine but also unnecessary.
Put it on a tender and leave it alone. The bike can sit for 3 or 4 months just fine.
Old Jan 6, 2014 | 08:01 PM
alame's Avatar
alame
+1.....tires don't flat spot, no such thing as cardboard/carpet preventing condensation or rust transfer !! lol
Old Jan 6, 2014 | 09:48 PM
Lowcountry Joe's Avatar
Lowcountry Joe
Originally Posted by howitzer88
Keeping the bike off of the ground that prevents electrical grounding.
hmmmmm. How's that work through rubber??
Old Jan 6, 2014 | 09:55 PM
RK14SGS's Avatar
RK14SGS
Default winterize
Originally Posted by SoCalMike
"Winterizing" What is this 'winterizing' you speak about?
Sorry . . . I couldn't resist. Peace out. Ride West.
We don't do that here in SC, sorry.... had to....
