Urgent towing question
Old Jan 7, 2014 | 01:07 AM
angelrod's Avatar
angelrod
Originally Posted by JohnTM
I don't know. I was asking the question. But, I assume in gear to act as a brake thus keeping the bike from moving and shock shelf way so there is minimal bounce and minimal bottoming out, in case of bumps.
my bad.it just a stupid comment
Old Jan 7, 2014 | 01:13 AM
dickey's Avatar
dickey
Never strap the bike down on the kickstand, and never cover it.
I usually bungee the front brake. There are 2 schools of thought on this,1 pro & 1 con. I dunno; I just do it & never a problem.
Old Jan 7, 2014 | 01:17 AM
ke5rbd's Avatar
ke5rbd
Put in neutral. Hauled mine about 700 miles inside enclosed trailer with it in gear and the lifters lost their prime. Started it and what a noise.
It won't hurt to leave kickstand down. Don't tie it down with it on kickstand. About half way down is ok on the front forks. Also tie the rear down where it can't bounce from side to side. Disarm the security or leave fob on it.
A tarp or cover is a don't do. It will rub the paint. Probably good idea to take windshield and bags off to keep them from getting etched from salt.
Don't know if I would attempt to haul it in the conditions you describe. Too likely to get damaged.
Old Jan 7, 2014 | 03:24 AM
gja's Avatar
gja
Get some soft straps and tie down at the front fender mounts. I've hauled my RG this way many times. Allows the suspension to work with no compression on the forks for a long period of time.
Good advice on the stopping a couple of times at the beginning of the trip to check the straps.
Old Jan 7, 2014 | 05:25 AM
Juice's Avatar
Juice
I though leaving in gear could damage shift paw/fork?
Old Jan 7, 2014 | 06:13 AM
Notgrownup's Avatar
Notgrownup
I tie the forks down also for double redundancy...i loop a ratchet tie around the forks where the fender is bolted to the fork....and i have bolted anchors to the side of the forks.
Old Jan 7, 2014 | 07:13 AM
chester1957's Avatar
chester1957
If your are using ratchet straps with hooks, wrap electrical tape around the hooks. If you get any bounce, they can't come unhooked. I have replaced the hooks on my straps with those screw to close chain links.
Old Jan 7, 2014 | 07:20 AM
Veekness's Avatar
Veekness
OP, you're obviously gonna have to sift thru a lot of opinions to figure out what works for you...and by now you're probably on the road...for me, ALWAYS in neutral, NEVER in gear. Suck the front forks down halfway so there's always tension on the front tie-downs. NEVER leave the jiffy stand down, and NEVER leave the bike on the jiffy stand. Good way to damage the stand, the frame, or both. You'll be fine, don't over think it, doesn't hurt to tie the back of the bike down to keep it from bouncing around, it's my habit, some say unnecessary, but I have had the back jump up a little bit and go sideways...Good luck...and, no tarp...ever.
Old Jan 7, 2014 | 07:23 AM
Scrmnvtwins's Avatar
Scrmnvtwins
Be sure the trailer has some means to secure the bottom of the wheels. If you have no rail to place the wheel in, ask U Haul idf you can screw a 2x4 into the wood floor on each side of the wheels. If you have no method for securing the bottom of the wheels, buy extra straps and after you have it strapped in from the top, place additional straps at the bottom to keep it upright and prevent the wheels from bouncing or sliding sideways which would loosen your upper straps. Also leave in neutral using 2 straps in fron pull to front of trailer followed by 2 straps in rear pulling same to front of trailer. Do not make these straps work against themselves. I like toadd 2 more to the back pulled to the side to keep it centered in the trailer and as mentioned above, if the wheels are not in a cradle or rail additional straps down low pulling sideways to keep the bottom center in the center of the trailer, once the bottom slides out all straps go loose and you lose the cargo. Straps are cheap, get plenty
Old Jan 7, 2014 | 08:57 AM
hvacgaspiping's Avatar
hvacgaspiping
I learned this the hard way. Do NOT attach the straps near the top portion of the forks where you have to pull down on the compression part of them. They will bottom out if/when you hit a reasonably large bump in the road, which will lead to fork seal replacement. Even pulling down only halfway as someone mentioned earlier will be very risky in this regard.
