Is your bolt head on the inside and the acorn nut on the outside?
yep, acorn nut on the outside.
Originally Posted by Grimace97
A stock shift linkage like 25 and uses a cuff joint
The fancy schmantzy ones for 130
Use a heim joint. Which is slickly better.
But not a 100 dollar difference. People may try to justify it. But it's a 130 dollars of chrome go fast doo dads.
thats why on my old bike, i spent about $10 and replaced the cuff joints with heim joints, and reused the stock linkage. and the heim joints vs cuff joints do give a better feel on shifting.
yep, acorn nut on the outside. thats why on my old bike, i spent about $10 and replaced the cuff joints with heim joints, and reused the stock linkage. and the heim joints vs cuff joints do give a better feel on shifting.
Is there any benefit to a different shift linkage over stock other than its pretty looks? More ridged? Better feel? Sexier?
The heim joint linkage is stronger, more reliable and provides a firmer feel at the shift level than the stock linkage. Styling is a subjective call, but the stock kinkage cheapens the appearance in my opinion.
