spark plugs?
Old Jan 12, 2014 | 09:26 PM
drukanfu's Avatar
drukanfu
Autolite 4164 or stock 6R12 every 2 or 3 yrs.
Here is a cross ref. chart.
http://www.harley-performance.com/ha...park-plug.html
Old Jan 12, 2014 | 09:27 PM
senna's Avatar
senna
Originally Posted by nhhdrider
Has anyone seen a difference between using the screaming eagle and standard OE spark plugs?
Is it worth the extra money?
Any performance improvement?
It looks like the SE plugs are iridium plugs which I always use in my cars / trucks.
The only difference I see is the SE plugs have a better fit to the boots on the SE wires. I put SE wires because I wanted red wires, then I noticed the boot was loose on the plug so I figured I would see if the SE plugs fit better, they did.
Old Jan 12, 2014 | 09:28 PM
dulley's Avatar
dulley
I use both on my 2011 r.g 103 I will stay with the s.e . , but I heard A LOT of good stuff about those ngk plugs I change mine every year so this spring im going to try them
Old Jan 12, 2014 | 09:53 PM
HDSAE60's Avatar
HDSAE60
I like the "E3" plugs. look up the test video on there web site and you will see why.
Old Jan 12, 2014 | 09:55 PM
ynots's Avatar
ynots
On my FXD I noticed no difference whatsoever
Old Jan 12, 2014 | 11:18 PM
mkguitar's Avatar
mkguitar
Originally Posted by skratch
i stick with the stock hd plugs for one reason. the ecm requires your spark plugs to be a certain ohm rating in order for the knock sensor to work properly. other plugs may fit, and they may or may not have the correct resistance. i know the stock hd plugs do. it isn't like you have to change them with every oil change anyway so to spend a couple extra bucks on the hd badge is no big deal.....
answers come from all over the place...the only answer that really matters is this.
IF your model's computer uses data from the plugs and wires for "ion sense", a plug or wire change may cause reduced performance...even screaming eagle stuff. IF the computer think that the motor is knocking or pinging, if may retard timing= reduced performance
oem stuff is fine.
plugs mattered more when ignition systems and fuel systems were less precise...a "great plug" could burn it's way through fuel mixtures which might foul a regular plug. ( like my old Panhead- i use platinum plugs)
2.) auto manufacturers need to squeeze the best MPG they can to meet CAFE standards, they also want to get best power for bragging rights ( both of these are mentioned in every car commercial I see).
- If using an E3, splitfire*, or magic plug provided these advantages, wouldn't GM, Ford and Fiat use them?
as above, these magic plugs will often 'win" in a test where the fuel delivery or ignition system is not performing at it's best.
mike
* here is where splitfire paid a fine for deceptive claims in 1997:
http://www.ftc.gov/news-events/press...ncy-claims-are
Old Jan 12, 2014 | 11:23 PM
TUCCI's Avatar
TUCCI
Originally Posted by QC
I've been using NGK Iridiums.
Me too, went with the VRod plug though. Been 10k now and they still look new.
Old Jan 13, 2014 | 03:01 PM
Elqueso2's Avatar
Elqueso2
I too have been running the NGK Iridiums.
Old Jan 16, 2014 | 06:57 PM
vtwin883's Avatar
vtwin883
iridium plugs fire the 1200 right up even on coldest day with little chock the work really well with our big bore . index them to exhaust valve for max power
Old Jan 16, 2014 | 07:46 PM
12hdrk's Avatar
12hdrk
Part number please...
