Power Vision and stock bikes
Old Jan 22, 2014 | 04:44 PM
VTL nut's Avatar
VTL nut
Originally Posted by Webo
I see your living in east Texas so I know your riding in the 100+ degree heat in our summers. You already de-catted the head pipe so get the PV and richen the tune up a bit and the bike should run noticeably cooler and have less ping in the hot summer. You will probably feel a nice power boost as well! My vote is a tuner is always a good thing even on a stock bike. These things are EPA lean to start with so the tuner will make a stock bike run better.
About sums it up........well put.
Old Jan 22, 2014 | 04:47 PM
Hausguy's Avatar
Hausguy
Originally Posted by lowbed
Can you use the handle bar mount for a GPS when not using the Power Vision? What does a stage 1 consist of? I am a new/old rider, have been without a bike for 25 yrs, now have a 2013 SG, so I have a lot to learn and relearn. I have a set of 4"Rinehart's and a head pipe that I have removed the cat from, stock exhaust is still on for now.
If you change to an open breathing air cleaner, your Stage 1 will be complete...after you get a tuner/tuner. Keeping the PowerVision on the handlebars is an option if you want to look at the gauges, etc. but to use autotune, you can keep it in the saddlebags or wherever. Once you flash the tune to the bike (ECM), the PV can be removed.
Old Jan 22, 2014 | 07:59 PM
Bullbutch's Avatar
Bullbutch
Unhappy
I kinda wish I bought my Power Vision from Fuel Moto rather than Dynojet. Fuel Moto is cheaper and comes with the visor and mount and seems like they have more maps available.
Old Jan 22, 2014 | 09:03 PM
Hausguy's Avatar
Hausguy
I don't think you're missing much by having more maps available. The key is to do a few autotunes. As for the visor...only important if you plan to mount the PV permanently. I didn't see a need to do that.
Old Jan 23, 2014 | 08:06 AM
lowbed's Avatar
lowbed
Thanks Hausguy, air cleaner and a 4 point/sissy bar combo are next on the list as mad money allows.
Old Jan 23, 2014 | 05:33 PM
Bullbutch's Avatar
Bullbutch
[QUOTE=lowbed;12232487]Thanks Hausguy, air cleaner and a 4 point/sissy bar combo are next on the list as mad money allows. [/QUOT
Wrong quote.
Old Jan 23, 2014 | 06:02 PM
Bullbutch's Avatar
Bullbutch
I didn't get the autotuner but if I had wouldn't I need to mount it to the bike to run it?
Old Jan 23, 2014 | 06:26 PM
Hausguy's Avatar
Hausguy
Nope. Depending on where you buy the PV, it will come with a custom "base" map. There are also a bunch of other base maps already installed that you could choose from. You could just load one of these tunes, then flash your bike with that and be done with it...unplug and put it back in the box. Once you've flashed your bike, you can run some Autotunes to fine tune your ride even more. You basically just turn it on and go for a ride. When you're done you update your bike and that's it. I did it a few times and am pretty much good to go. While doing the autotune, I just kept the unit in my saddlebag and went for a ride. I'll probably do another one and then it will go back in the box.
By the way, Basic Autotune is free and comes with the PV and it works with the stock O2 sensors. You can also buy the Autotune PRO which requires different sensors and is supposed to be a notch better than the basic.
Old Jan 23, 2014 | 06:53 PM
Bullbutch's Avatar
Bullbutch
Thank you very much. I can't wait for all this snow to melt to actually get out to put the new exhaust put on. I went on youtube and look at a video about the basic auto tune.
Old Jan 23, 2014 | 08:53 PM
mikeman54's Avatar
mikeman54
Have had the pv on three bikes 010 Ulta 013 Ultra and currently on my 014 Ultra,I got the package from Fuelmoto 2-1-2 stainless catless headpipe 4in Jackpot mufflers and the PV,and jamie sent it all ready mapped for your bike.IMO,this is a quality backed company with a awesome product and customer service that will wake that bike up..
donr101395
Mar 6, 2016 09:23 AM
slowrollin
Jan 10, 2016 10:15 PM
JamieDTR
Mar 22, 2014 09:03 PM
Bluraven
Apr 6, 2013 12:44 PM
AussieTX
Jul 23, 2011 06:23 AM
