Stator is toast
Old Jan 24, 2014 | 10:06 AM
mountain man's Avatar
mountain man
Possible clutch ??
Old Jan 24, 2014 | 10:47 AM
Hogpro's Avatar
Hogpro
Former Sponsor
The complete 50amp upgrade kit is part number 2212-0408 $524 retail. You can also get just the stator instead of the full kit for quite a bit less. If you need this stuff i can order it for you. Give me a call. I can provide discounted pricing as well.
Old Jan 24, 2014 | 10:56 AM
Pelonz's Avatar
Pelonz
No my clutch is solid no slipping whatsoever.
I found this tech read interesting http://www.cycleelectricinc.com/ explaining the OEM stator issues.
I always forget about Amazon, CE 3 phase 50 amp kit is on the way. My indy will install it for $150. I figure my time is worth more not to mention I don't have to deal with the special tools BS.
Thanks to all for your input. I'll update after install.
Old Feb 1, 2014 | 07:49 PM
Pelonz's Avatar
Pelonz
Road tested today and all is back to normal. Indy had no issue installing the CE 3 phase 50 amp kit.
Old Feb 1, 2014 | 09:07 PM
drspencer's Avatar
drspencer
Is this HD High Output Charging System 3-phase?
http://www.harley-davidson.com/store...harging-system
Old Feb 1, 2014 | 11:29 PM
DAVENRINO's Avatar
DAVENRINO
I think I paid $400 for that setup direct from Powersport parts last year.
Old Feb 1, 2014 | 11:48 PM
DeJavu's Avatar
DeJavu
It sounds like your regulator. Check the diodes thru the connector. The resistance should be 0 ohms one way and 1 ohm with probes switched. The fluctuating voltage is a result of no regulation. The coils were making max voltage and heating up. That could be the smell. The fact that you were getting any charging at all would point to stator being OK.
jo jo jo
Jan 24, 2017 10:54 AM
escalade6103
Sep 6, 2015 02:39 AM
ultra97
Aug 16, 2010 11:25 AM
Taylorized
Aug 14, 2008 09:42 PM
Steve On 3
Dec 14, 2007 11:20 AM
