Battery Problem, or something else going on?
Old Jan 26, 2014 | 11:02 AM
lionsm13's Avatar
lionsm13
It's not a bad idea to replace your battery every 2-3 years either w/the one that many of us are using on this site. http://www.batterymart.com/p-Big-Cra...-fl-flh-1570cc
Many will scoff at this though,(replacing their battery so often and this is your option) but I would rather be on the safe side and have a battery that would start every time and replace it every 2-3 years then I would be to get caught out in the middle of bumfak just once.
Old Jan 26, 2014 | 12:37 PM
mkguitar's Avatar
mkguitar
Originally Posted by danny54
Its not your VR Its most likely your battery, My 2011 ultra VR always reads high, MY BATTERY ONLY LASTED 2 YEARS.
if you VR reads high, above spec...than you know why your BATTERY ONLY LASTED 2 YEARS.
the specs and easy, simple test procedures are easily available.
Mike
Old Jan 26, 2014 | 01:05 PM
chamokie's Avatar
chamokie
Originally Posted by bigdumbnoitall00
not sure of year think it was 12 they had some bad voltage regulators.
Yes it was the 12's, I had to have mine replaced, it bounced the whole range of charge and discharge. There was factory recall on those
Old Jan 27, 2014 | 03:52 AM
slapshot12's Avatar
slapshot12
That's exactly what my '11 did when the battery was crapping out. The voltmeter was almost at or over 15. When I started it, it would crank once, delay a second or two, then fire up. The battery was OK voltage wise but didn't do so great on the load test.
I put in a new HD battery and the volt meter went back to the normal 14ish and it cranks right up with no delay.
TheBuckley
Jul 8, 2018 08:51 AM
adamk
Electrical/Lighting/Alarm
11
Mar 31, 2015 04:22 AM
ryanlberg
Apr 11, 2012 04:10 PM
hucks 08
May 26, 2010 07:23 PM
gsparesa
Dec 16, 2005 01:17 AM
