Who uses heel Shifter?
Old Aug 2, 2007 | 01:25 AM
  #121
cabbage's Avatar
cabbage
Default RE: Who uses heel Shifter?
i removed first day i got the bike.....however, after spraining my ankle and being unable to lift with the foot, i put it back on last week and it is working well for me with the injured hoof.
Old Aug 2, 2007 | 02:11 AM
  #122
Scorpio49's Avatar
Scorpio49
What is involved with adjusting the heel shifter. Want to lower it so I don't have to hike my heel so high to use it.
Thnaks
Old Aug 2, 2007 | 04:28 AM
  #123
tizone's Avatar
tizone
I love the heel shifter. Although I need to adjust mine down a bit and would like a longer than stock lever to move it back off of the floorboard.
Old Aug 2, 2007 | 04:35 AM
  #124
db2753's Avatar
db2753
If we are still comparing sizes, I'm a proud 12.
Old Aug 2, 2007 | 05:36 AM
  #125
DensFLH's Avatar
DensFLH
Mine fell off several times while on a road trip to Niagra Falls. I guess I was lucky I didn't loose it becaused it wedged between the floor board and engine. I took it off and left it off, since I never used it.
Old Aug 2, 2007 | 05:48 AM
  #126
glens's Avatar
glens
I'm only a 10-1/2 - 11 but have nice proportions
Was asked what's involved in adjusting the rear too-short shift lever. Here's how I did it (am not too sure about the number of splines at this point but you'll see what you need to do for yourself when you get to it).
First off, I gotta say I can see the reasoning behind using the same part for both but why the Sam H-e-double-l didn't they make it 1/2" longer and put the floorboards 1/2" farther forward?
When I loosened the clamp bolt, slid it off the spline shaft, and put it back on two splines lower it would hit the floorboard. As I recall, I could jam it down anyway and it would work, compressing the floorboard mat some. But I was concerned both about reliability and having it kicked out of my selected gear while going through a curve dragging my floorboard. So I detached the shift linkage and extended it a couple of turns. This rotated the shift levers forward which gave me the clearance I wanted in back and served to rotate the front one down some at the same time. I might have lowered the front by a spline itself, too.
Old Aug 2, 2007 | 06:06 AM
  #127
Badbagger's Avatar
Badbagger
Size 12 here but I sure do use it.
Old Aug 2, 2007 | 06:09 AM
  #128
1of2's Avatar
1of2
"Moderator"
I don't use mine much but I like it on there. I guess I like the looks of it more than the function.
Fatboys have that old school look and it adds to it.
Old Aug 2, 2007 | 06:49 AM
  #129
Pastor John's Avatar
Pastor John
Use it all the time - don't want to mess up my Ostrich boots!
Old Aug 2, 2007 | 07:46 AM
  #130
bonz50's Avatar
bonz50
i run a size twelve, 90% of the time i use the toe, i have found though that when in top gear the heel shifter makes a nice place to rest your foot once in a while to change up your riding position... what i'd like to see is a heel shifter that is about 1-2" longer (further back) so there is extra room on the board also could have a hinged/spring loaded peg mount so that it would fold back out of the way and help keep pant legs and boots from getting caught on it... maybe i should start making/selling them??
