Hey for those that price each one of these separately, all of these items go well over 570. The rack, lights, and detachable plate kit separately totals about 569. So this is a bargain. Im thinking of getting this for my road king and sell the parts for profit.
For those of you who have already fitted the HD Detachable Tour Pak kit to a Rushmore ...... I want to fit it but I will still want to use the tour pak, and when I do, I want all the lights/speakers/electrics to work but there is no mention made of these in the kit. What's the solution?
Cheers
Ruth
Did you install the 53000291 on your bike? If so do you have the J# on the top of the install manual. I'd like to look up the PDF online for it
If you go to link provided, click more info tab, the PDF instructions are there. I believe they reference separate instructions for the lights so you find the saddlebag glo light kit and click the more info tab on those.
Cheers
Ruth
The tour pak lights will work when tourpak is mounted along with the saddlebag lights. Speakers too.
I will be installing the detachable tour pak on my 2015 SERGUltra. I saw it on a bike at Timpanogos HD in Lindon UT. I called Chris 801-434-4647 (parts dept) Here is what they did.
53000221, 52300353, 76000513, 69200921. Then From Drag 4402-0096 and 1905-0000
I have also ordered 3 single LED lights to install under the Brake light bar. I will post pictures when done.
The 4402-0096 is J&M FPA-HCCB hidden CB antenna and fits 2006 to 2013 Batwing & Road Glide models. What you need is the J&M FPA-HCCB-14 for 2014 & up models - although I would confirm this works on RG models also as they only list Batwing models but I can't see why it wouldn't. For whatever reason, Drag doesn't carry these. We have one in stock at work.
