Changing gauge bulbs
Old Sep 10, 2014 | 04:56 PM
  #31
harleyboy63401's Avatar
harleyboy63401
Does placing the LED bulbs in the gauges require a load equalizer?
Thanks!
Old Sep 10, 2014 | 05:49 PM
  #32
vtwinbmx's Avatar
vtwinbmx
No it does not I did my 07 without issues
Old Sep 10, 2014 | 06:48 PM
  #33
Toofat's Avatar
Toofat
Originally Posted by skratch
i changed the small gauge lights on my roadglide without taking off the outer fairing. just took the headlights out and went in that way.
look around on ebay. i found a seller that was selling the plug in leds (pretty sure they are w194) for $5.00 for 10 with no shipping. i bought 10 in blue and 10 in white.
You won't be able to do it that way on 09 and older Road Glides. On those models the headlight mounting screws are on the backside of headlight mount. You'll have to pull outer fairing to get to gauge bulbs.
Old Sep 11, 2014 | 11:23 AM
  #34
bagman1's Avatar
bagman1
I have an 07 and did the leds for gauges. How did you prevent the lights from flickering? I have the wire end and the newer style corcuit board ends. The wires will flicker and the cb end wont stay in the socket, it pops out when trying to install
Old Sep 11, 2014 | 11:51 AM
  #35
jamess71's Avatar
jamess71
I didn't have any luck with the circuit board end type either. The ones with the wires I always bend the wire out and put a little more bend on it so it sticks out further to make better contact with the socket. No problems after doing that.
Old Sep 11, 2014 | 12:10 PM
  #36
vtwinbmx's Avatar
vtwinbmx
Did you order the right ones ?
Wled-xhp5 ( the x is color choice) they plug right in. If they don't work rotate the bulbs 180 degrees.
  #37
vtwinbmx's Avatar
vtwinbmx
https://www.superbrightleds.com/moreinfo/wedge-bulbs/194-led-bulb-5-smd-led-wide-angle-wedge-base/206/
Here the link
Old Sep 11, 2014 | 01:57 PM
  #38
bagman1's Avatar
bagman1
Yes theyre the right ones. I got them from the same place too
Old Sep 11, 2014 | 03:09 PM
  #39
vtwinbmx's Avatar
vtwinbmx
Strange. I never had an issue. Ran mine for years without any problems. Hit up myride7 here on forum. Marty is the king of led mods he might have some information to share with you. He also has a website that you can contact him directly. Www.gaugeledmods.com
Cozz
Jun 14, 2019 09:28 AM
Smokin751
Feb 16, 2015 09:42 AM
VROCK SE
Jun 25, 2013 06:48 PM
1931jamesw
Feb 9, 2012 03:32 PM
HOG_0308
Aug 16, 2010 07:31 PM
