Starter leaking... help
Old Feb 3, 2014 | 10:01 PM
ke5rbd's Avatar
ke5rbd
Originally Posted by hvacgaspiping
Why black silicone? I thought the red was the high heat stuff?
The black is oil proof, or atleast few years ago it was. The red probably is too, but would stick out like a sore thumb. They also make O2 safe silicone. I suspect you would have to put the non safe in the intake area before it would mess up the O2's.
Old Feb 3, 2014 | 11:35 PM
Bingee's Avatar
Bingee
You shouldn't need any sealant if the o-ring is in place. But then maybe it still does. Check with a shop for the right kind to use. Did you replace the starter clutch or rebuild it? Check to make sure the pinion gear bearing has an oil seal in it. Some were made without one. Also check the oil level in the primary. Make sure it's not getting overfilled with engine oil in it.
Old Feb 6, 2014 | 11:37 AM
Bostonbaggah96's Avatar
Bostonbaggah96
Didn't realize there were more o rings inside. Have to take it apart and check the starter itself. I got my starter rebuilt but when I called they had givin me a already rebuilt starter they had on the shelf. (My fault told them I needed it done ASAP starter died 3 days before bike week). Thanks for the tips everyone
buellrider76
Sep 9, 2011 10:16 AM
krazedstang
Jul 27, 2009 12:31 PM
AZ RKC
Apr 20, 2008 11:25 AM
jermil32
Ironhead
Sep 13, 2007 09:33 AM
DGlide04
Aug 26, 2006 07:51 PM
