Visor Style Headlamp Trim Ring?
Old Feb 4, 2014 | 12:29 PM
JafaDog's Avatar
JafaDog
Still have a slight gap after numerous attempts to fix it--Irwin clamps, backing off the stock trim ring screw, anti-sleeze--nothing worked. I just decided to live with it rather than spend $$$ on one that has no gap (Kuryakyn, etc.).
Old Feb 4, 2014 | 12:44 PM
jackass dave's Avatar
jackass dave
ihave one it came fitted with the bike never looked at it ,so ill have a look tommorow and see if i have a gap
Old Feb 4, 2014 | 12:45 PM
my67pnycar's Avatar
my67pnycar
You have to loosen the OEM ring just a bit, make sure the French trim ring snaps BEHIND the OEM trim ring, use a small set of needle nose vice grips to pinch the ends together so you can get the little nut and bolt started, tighten until the gap goes away, winner winner chicken dinner.
Old Feb 4, 2014 | 02:26 PM
Turret_plug's Avatar
Turret_plug
Originally Posted by Rustrtal
Pics duh! One of the wife hand job gap and one of the dish towel strap wrench method.
Ok, let's keep it clean! Lol
Old Feb 4, 2014 | 04:20 PM
mr2fast4u's Avatar
mr2fast4u
I have more time into getting this to fit properly than I would like to admit
no pics, but what I did was
removed stock ring
drilled and installed four small bolts in the headlight retainer ring?, trial and error here to get tight fit and no gap
then I spaced the headlight retainer ring? out from the fairing with three small washers (real bitch, I ended up taping these together and redoing whole through the washers taped together)
HTH, way too much time but the gap is tight
Old Feb 8, 2014 | 07:12 PM
escalade6103's Avatar
escalade6103
this is how i solved my install issue and some pics to go along with it. the tape i used is sticky but not adhesive on the outside and i wrapped a few times so when i tightend the ring down it compressed the tape just a bit. this method is just like using just the original ring and its easy to remove/install whenever you need to for adjusting headlight and stuff
1. removed trim ring.
2. removed headlight bucket.
3. wrapped the edge of the bucket with black rubber pipe wrap (its in walmart plumbing section $9)
4. reinstalled headlight bucket
5. installed headlight visor ring without original visor
Attached Thumbnails Visor Style Headlamp Trim Ring?-photo-1-3.jpg   Visor Style Headlamp Trim Ring?-photo-2-4.jpg   Visor Style Headlamp Trim Ring?-photo-4.jpg   Visor Style Headlamp Trim Ring?-photo-3-1.jpg
Old Feb 9, 2014 | 03:37 AM
jackass dave
yes i have a gap on mine not much of a gap so i can live with that
Old Oct 12, 2014 | 03:35 AM
lhgdale's Avatar
lhgdale
Don't mean to restart a old thread but does anyone know the bolt size that tightens the trim ring? I stripped the original phillips head bolt out and need a new one. I would really like one with a hex head instead of the phillips. My headlight seems to be a little loose from loosening the stock ring and I need to play around with it some more.
Old Oct 12, 2014 | 06:03 AM
utz's Avatar
utz
this install drove me crazy as well and I to have a bit of a gap in mine and its staying...lol
Old Oct 12, 2014 | 08:49 AM
vickers1's Avatar
vickers1
Originally Posted by Sinninger
I read a previous thread on this subject that suggested backing off the mounting screws of the original trim ring 1/4 turn. This allows the back lip of visor trim to slide behind easier. Worked for me, didn't have to fight with the screw at all.
Worked for me too. Not perfect but good enough for me.
05dlx
2014-2024 Touring Models
11
Oct 3, 2014 05:18 PM
canicta
Mar 28, 2013 09:06 PM
mikebaby
May 3, 2012 08:03 PM
jsciullo
Oct 21, 2010 08:25 AM
Hog Heaven
May 1, 2008 06:05 PM
