FLHTC Project
Old Feb 7, 2014 | 04:51 PM
Fozzy4325's Avatar
Fozzy4325
Default FLHTC Project
The Bike is a tribute bike to the members of the RAF Regiment and all who have fallen.
Bike Name = Through Adversity
Colour Scheme = Same as the Regimental stable belt. Navy Blue, Assure blue, Maroon
AirBrushing = all unti crests and fallen names are air brushed and gold leaf.
Chrome = All crome is being removed and its going be 3 types of black: Denim Black Console, Wrinkle black Engine casings and parts, All other chrome is Gloss Black.
Bolts = All Bolts are dry filmed black
Engine
Stock 96ci - Modified
Stock Heads - Installed
Revolution Performance 107 Kit 10.5.1 - Installed
Tw/Can Steel T/Saver p/rod - Installed
Fueling 574 Camshafts - Installed
Stock Injector - Installed
Air Filter (PRM Jet Stream Intake) - Installed
2009 Model (127-71578) SuperTrapp Kerker 2:1 SuperMegs for Harley Davidson FLH/FLT 2009 in Black Finish - Installed
ECU replacement (Thundermax) - Installed
Dipstick - Black - LED - Installed
V-SHIELD HORN COVER, BLACK - Installed
Wheels
Dunlop Signature Tires - 130/60B19 Blackwall - 19 in. Front-43100013 - Installed
Dunlop Signature Tires - 180/65B16 Blackwall- 16 in. Rear-43200027 - Installed
Black contrast Enforcer 19 in. Front Wheel - Installed
Black contrast Enforcer 16 in. Back Wheel - Installed
Lyndall Carbon Rotor x2 front - Installed
Lyndall Carbon Rotor x1 rear - Installed
LBS Gold Break pads - Installed
Wheel Mounting spacer Kit Service kit front - Installed
Wheel Mounting spacer Kit Service kit back - Installed
Audio, GPS and Phone
Polk Audio AA2651-A MM651 6.5-Inch Coax Speaker - Installed
Kenwood KMR-555U - Installed
Massive Audio BX4 (via Sonic electronics) - Installed
Stereo Cables (via Sonic electronics) - Installed
Stereo Mounting Kit - Installed
Steering wheel control interface - Installed
Boom Audio Antenna - Installed
HAWG WIRED 6.5 SPEAKER ADAPTER RINGS BLACK 98-13 HARLEY FLHT - ELECTRA GLIDE - Installed
Hog Tunes Saddle bag lids with Speakers - Installed
Garmin: External Microphone 010-10804-00 - Installed
Garmin zumo 665LM (010-00727-08) - Installed
Waterproof Motorcycle iPhone 4S Tough Case Mount Bundle with Direct to Battery Charger (sku 13453) - Installed
GPS Antenna Mount - Installed
BLACK TWEETER DASH PODS Not being installed
Fabrication Mounting kit GPS - Installed
Lighting system
Genesis Amber Fender Tip LED - Installed
Fender tip lens smoked - Installed
Day Maker Main Light - In But Not Installed
Day Maker Auxillery Lights - In But Not Installed
Custom Auxillrty Lighting kit Black - Installed
LED HALO PASS. LAMP TRIM RINGS, BLACK - In But Not Installed
LED HALO TRIM RING BLACK H-D TOURING - In But Not Installed
Independent Control Auxiliary Lamp Wire Harness - Installed
LIGHTED BAT LASHES, BLACK CHROME - In But Not Installed
Tri bar fender tip extension - Installed
Bullet Rear Turn Signal Bar and License Plate Relocation Kit-53702-04A - Installed
Layback LED Tail Lamp-67800358 - Installed
L.E.D. SADDLEBAG EXTENSIONS, BLACK/SMOKE - In But Not Installed
Kuryakyn Load Equaliser 2 Amp - In But Not Installed
Kuryakyn Load Equaliser Adapter - In But Not Installed
DEEP DISH BEZEL/SMOKE LENS, BLACK - Installed
Wrap Around Dual Intensity LED Fender Tip Not being installed
SINGLE CIRCUIT AMBER LED BULB - Installed
TWO CIRCUIT AMBER LED BULB - Installed
Grips, Foot pegs and Controls
KINETIC SHIFT PEG, BLACK - Installed
KINETIC BRAKE PEDAL PAD FOR FL, BLACK - Installed
KINETIC PEGS BLACK MALE MOUNT - Installed
KINETIC DRIVER BOARD INSERTS, BLK, TRAD - Installed
KINETIC PASS BOARD INSERTS BLACK, D-SH - Installed
KINETIC GRIPS, BLACK 08-UP ELEC THROTTLE - Installed
Hand Control Lever Kit-38845-08 - Installed
LONGHORN OFFSETS W/1-1/4" CLAMPS, BLACK - In But Not Installed
Other
Fairing Mount Mirrors - Installed
Universal marine receiver cover - Installed
Touring pack - Installed
touring pack mounts - Installed
Fender Strut Covers-47498-09 - Installed
Number plate - Installed
Tripper™ Solo Seat Harley-DavidsonŽ FLHT/FLTR/FLHX/FLHR - In But Not Installed
Tripper™ Rear Seat Harley-DavidsonŽ FLHT/FLTR/FLHR/FLHX - In But Not Installed
Antigravity Batteries YTX12-24 Lithium Ion Ultra Lightweight Battery 720cca 5lb - Installed
Optimate Lithium Charger
Micro Start PPS XP-1 Kit Personal Power Charging and boosting kit
Security
Kryptonite disk locks - Installed
Kryptonite chain 60 inch - Installed
Thermastat mount - Installed
Just need to get insurance, Assessment and a GPS tracking device
Paint work
Maroon and Navy Blue is going to be:
House of Kolors on a Marbleised base
The Light Azure blue has fine flek with white candy coat over it.
the words are going to be gold leaf paint
the joining line between each of the colours is going to be a pin stripe of the opposite colour. e.g. Marron to Light blue with a navy blue pin stripe etc...
Bike (Concept)
TANK (Actual)
The batwing has our Regiments Crest (Concept)
(Actual)
Front fender with pin stripe wheel
Front Fender(Concept)
(Actual)
Rear Fender (Concept)
(Actual)
Right Pannier
Left Pannier
Front and back of panniers
Side cover
Last edited by Fozzy4325; Jun 18, 2014 at 05:49 PM. Reason: more brothers to add to the wall of honour
Old Feb 7, 2014 | 04:56 PM
mkguitar's Avatar
mkguitar
Cool, my Dad was RCAF ( flew out of Penhold just N of you, Cold Lake, way N of you...amongst other places- North Allerton, Yorks for another).
Those colours are very familar, I grew up with them around the house.
I'll be up for The Stampede this year- I'll watch for your ride.
Mike
Old Feb 8, 2014 | 12:22 AM
zeus33's Avatar
zeus33
Big Kahuna HDF Member
What a great tribute. Its a great plan and it's going to look really nice when it's done. Looking forward to seeing the after pics.
Old Feb 8, 2014 | 12:44 AM
Fozzy4325's Avatar
Fozzy4325
It has to be ready by 1st April but I hope to have it before then.. I will be waiting more than 4 weeks for the wheels as they have to come from the states.
I'm going to get a professional photographer into make some photos.
Old Feb 8, 2014 | 12:37 PM
tagalongtrouble's Avatar
tagalongtrouble
Excellent tribute..ride proud
Old Feb 8, 2014 | 05:46 PM
Fozzy4325's Avatar
Fozzy4325
Many thanks I will. The Regiment have heard about it and are stoked to see it
Old Feb 8, 2014 | 06:22 PM
Smitty79's Avatar
Smitty79
Awesome tribute. Thanks for sharing.
Old Feb 24, 2014 | 07:34 PM
Fozzy4325's Avatar
Fozzy4325
cleared the text
Old Mar 1, 2014 | 03:08 PM
Fozzy4325's Avatar
Fozzy4325
Updated and added new photos
Old Mar 2, 2014 | 01:08 PM
Xcrossbow's Avatar
Xcrossbow
That's some project. Anxious to see more photos. Looks like you've listed everything but did I miss the windshield? Is that a 8.5" Klock?
Also, I have the all blackened Enforcer Wheels like in your one photo and I am interested in seeing what the "Black contrast" Enforcer will look like. My first choice with the wheels was with the black but having the inside of the spokes done something like the lever pictured below which Harley calls a "contrast cut". I ended up getting a great deal on the all black Enforcers so I went the way. Good luck.
