Odometer discrepency?!
Old Feb 16, 2014 | 10:13 PM
0ldhippie's Avatar
0ldhippie
Originally Posted by FinalShot
Unfortunately, the PV does not allow you to change the odometer setting, only the speedo.
Wow, thought they would be tied together, never actually checked it. Good to know.
Old Feb 16, 2014 | 10:28 PM
SafetyMan's Avatar
SafetyMan
So what I am reading here is that the odometer is not linked to the speedometer?
Documentation? I can't see having 2 sensors, since they essentially read the same thing.
I've been wrong before....
Old Feb 16, 2014 | 10:33 PM
Gonzy's Avatar
Gonzy
Gonzy
When I had my 2010 RK my speedometer was off about 5 mph. When I went on rides with some of my riding buddies I would show a higher mileage than what they had for the same identical trip. I finally had the dealer check it out and they replaced it under warranty. So I do believe that the speedo and the odometer ARE tied into eachother and not working independently.
Old Feb 16, 2014 | 10:36 PM
hover's Avatar
hover
True, there is only 1 speed sensor.
Old Feb 16, 2014 | 10:44 PM
SafetyMan's Avatar
SafetyMan
That was my belief, but there are posts in this thread that claim otherwise.
Old Feb 16, 2014 | 10:52 PM
hover's Avatar
hover
Ya but those other guys are speculatin lol
Old Feb 16, 2014 | 11:02 PM
SafetyMan's Avatar
SafetyMan
Ten dash four on the speculation.
Old Feb 17, 2014 | 12:01 AM
FinalShot's Avatar
FinalShot
Hmmmm, maybe I'm wrong, won't be the first......
It could be just a small difference then. My speedo was off by about 5 mph at 70. After I made the change with my PV, I made my normal trip to work. It always showed 32.3 to 32.5 miles and gps was always 30 - 30.1 miles. After I made the change to the speedo, it showed the exact same 32.3 to 32.5 miles.
I wonder if I run the PV numbers up and down and go for a test frive if that would be tampering with the odometer!
Old Feb 17, 2014 | 12:48 AM
Sam2010's Avatar
Sam2010
That explains all the low mile Harleys people are ******* the speedo...
Old Feb 17, 2014 | 04:14 AM
'05Train's Avatar
'05Train
One sensor. Change the speedometer calibration and you change the odometer calibration. Takes no time at all to adjust with a PV or TTS.
