Sg inner and outer fairing not mating up?
Old Feb 18, 2014 | 10:59 AM
ridedaddy's Avatar
ridedaddy
Default Sg inner and outer fairing not mating up?
I've had my sg apart for various reasons over the winter and I've noticed now that my outer faring isn't mating up properly with the inner fairing. It's only at the bottom on the cigarette lighter side. On the bottom beneath the lighter plug the inner fairing should slip in the outer fairing and sit flush so to speak. It mates up perfect on the brake lever side but on the clutch side it doesn't go in all the way? About half of the rubber molding only at the very bottom is exposed? It can be pressed together for the most part but just flexes back out. I've tried making adjustments to the chrome skirt under the headlight, I've played with where the fairing support brackets bolt to the triple trees also. Not sure where the problem is coming from? Anyone else been down this road?
Old Feb 18, 2014 | 11:22 AM
07JakeelwoodHD's Avatar
07JakeelwoodHD
Something is in the way behind faring push everything gently in wiring harness etc don't break anything check all around inside and outside you may have stripped the brass insert and the bolt is not going in all the way....Don't ask me how I know easy fix only cost about a buck Joe
Old Feb 18, 2014 | 03:31 PM
ridedaddy's Avatar
ridedaddy
Ok thanks, I painted the inner fairing, added a amp and speakers and installed 10"apes so anything is possible I guess.
Hades02
Audio Systems
Feb 25, 2015 10:39 AM
gas_sux
Aug 6, 2013 07:18 AM
scot210
Jun 13, 2011 11:23 PM
blown alcohol
Feb 2, 2010 10:52 PM
Grunt66
Oct 14, 2006 05:14 PM
