18 inch Rear Rims DO NOT WORK
Old Feb 19, 2014 | 10:28 PM
trackadaptor's Avatar
trackadaptor
The Bike is Not Lowered - on my Sig its the Blue 2007 FLHX
His Running 12" Works Spring Shock - set up for 75% 2 up riding
The: 150 Vs the 140 is Taller
The: 150 70 18 is 1.200 inches Taller -
How can you fix loosing 1.2 inches of Travel
Its rubbing the bottom of my buddies fender - its real bad....
The Width: Had to remove the Belt Guard - this is No Big Deal
PM Wheels
http://www.performancemachine.com/mo.../finishes.aspx
Originally Posted by Hogpro
Here is the breakdown on rear tires and what years they fit with an 18x4.25 rear wheel. 2000-2003 the widest tire is a 140 as the belt is 1.5" wide. 2004-2008 150/70/18 fits fine. Never seen a problem but apparently you have one. 2009 and newer sizes change as they have a wider rear wheel but that is not the issue here.
If you are running lower than stock shocks (shorter than 12") with an 18x4.25 you want to double check the clearance between the fender and top of the rear tire. Whoever has the belt rubbing, what size is your tire, wheel and what year is your bike? What kind of wheel are you running? Where did you get it?
Wheels are a specialty item and it is best to deal with a place that has a lot of experience with that specific item as opposed to a "we sell everything" kind of place who blows stuff out for pennies on the dollar as some sales people have a tendency to say anything to make a sale.
In my years in the wheel industry I am yet to have an issue with an 18x4.25 on the rear of a 2006-2008 FLHX. Is your bike lowered? If so how? How much? Does the wheel have the proper hub on it? Who installed it? What is rubbing. There is so much more information necessary to help you with your issue. It is my pleasure to help but I need to know more please.
Old Feb 19, 2014 | 10:34 PM
trackadaptor
Nice Bike !
But how did you fix loosing 1.2 inches of Travel ?
The 150 Vs 140 Tire is 1.200 inches taller , is your fender Stock ?
he's running 12" Works shocks so did something happen to his frame ?
We cant figure how you can run a Taller tire and not Rub.....
Originally Posted by DuraGlide
08 with the stock fender under the overlay and a 150/70 18 Metz. Did not rub with the air ride slammed. Did 2 up on the Dragon with no issues.
Old Feb 19, 2014 | 10:41 PM
Hogpro's Avatar
Hogpro
Former Sponsor
Hmm. That is an odd quandry. I literally sell this size wheel for your year and model bike many times weekly and never have issues. An easy fix is to put taller shocks on but I tend to think something else is wrong. Hard to say without seeing the bike in person but PM is usually spot on with their information as well. You don't become the biggest wheel company around without knowing your stuff.
I'm not saying you are wrong, only speaking from personal experience. I know there is an exception to every rule as well.
Old Feb 19, 2014 | 10:48 PM
trackadaptor
Wow
It states 4.2" Taller 150 Vs 140 but I think that's a "Overall" dim.
We got 1.2 inches taller
When you loose 1.2" of travel ya can't get it back
Originally Posted by Biggzed
What are you basing your "BS" on? Did you try it and it rubbed? Besides, I don't think your numbers are right. First, I've never seen a 140/70/16 on a Harley. 140/80/16 yes. Even if it was a 140/70/16, I don't think your 1.2" is correct either. I think it's more like double that.
Try using this. http://www.discounttire.com/dtcs/infoTireMath.dos
I think your just looking to get a rise out of people.
I ran a 150/70/18 in both Metzler and Avon for over 25,00 miles on my 07 Road Glide. Ran 12" Progressive 440's. It never rubbed.
Zach
Old Feb 19, 2014 | 10:55 PM
trackadaptor
Well my buddy thanks for all your input, he just may have some kind of problem....
Ride safe
Old May 21, 2019 | 09:41 PM
Roudie111's Avatar
Roudie111
Stage IV
Default 18” 4.25 rim with 140/70 18 tire
Works perfect. New chrome rear pulley, matched the 1.5” 70T stock, came with a spacer that I DID NOT USE, and everything worked perfect. Have between 3-8 and 1/4 gap with the belt. I’m 6’5” 270lbs and wife is 120lbs and zero issues with any rubbing or clearance when we ride.
Old Jan 18, 2021 | 09:25 PM
David Almond's Avatar
David Almond
Stage I
Originally Posted by trackadaptor
2006 - 2008 FLHX
PM Wheels and all you other After Market guys are full of it
Fact: Metzler 150 70 18 is 1.200 Inches TALLER than 140 70 16
So how you do you clear the fender rub...
Ya get a 16 inch rim and 140 70 16 Tire
I'm looking forward to Pictures that prove me wrong
i have a 180 90 16 on the back of my 99 1200c and its lowered
Old Jan 19, 2021 | 07:44 AM
decencyxdefied's Avatar
decencyxdefied
Cool story
Hessmonster
Oct 30, 2013 12:23 PM
speedracer
Nov 7, 2011 04:36 PM
bald1der
Jul 30, 2011 04:43 AM
epfatboy
Wheels/Tires
Jul 20, 2011 05:43 PM
fatboy1729
Dec 25, 2007 05:28 PM
