Bottom Fender Light
Old Feb 20, 2014 | 08:24 PM
glider_6969's Avatar
glider_6969
6th Gear
Default Bottom Fender Light
Hey All,
I need to replace the rear fender running light(bottom of fender) on my 07 streetglide (again) I seen there is an upgrade where this light can be upgraded to a run/brakelight. Anyone done this to their's and did you have any issues?
Old Feb 20, 2014 | 08:26 PM
T_Dogg80's Avatar
T_Dogg80
Just did it to mine. Took 10 mins. Works great. Can see it in my sig pic.
Old Feb 20, 2014 | 08:30 PM
Rustrtal's Avatar
Rustrtal
What is the upgrade/mod?
Old Feb 20, 2014 | 08:58 PM
T_Dogg80's Avatar
T_Dogg80
I imagine this is what he wants. I got the smoked one.
Old Feb 20, 2014 | 09:33 PM
jlj6t's Avatar
jlj6t
Originally Posted by glider_6969
Hey All,
Did mine not too long ago. Like TDogg, I used the smoked version of H-D's LED rear fender tip light. Stupid easy install, as long as you aren't also using/installing the H-D LED rear turn signals.
The only problem I had was wiring the "brake" wires from both the H-D rear LED turn signals and this fender tip light. H-D's instructions tell you to utilize the same slot for the brake wire. The turn signal instructions say use pin 2 of the fender tip light socket. Which is great, as long as it's a stock fender tip light and not already using pin 2 like in the LED fender tip light...
Two terminals, one slot. I cut the terminal off of one, stripped the insulation a bit, tinned the stranded wire, and jammed it into the Pin 2 slot along with the terminal from the other. Not mil spec by any means, but it's secure and seems to work.
Old Feb 20, 2014 | 09:36 PM
NCBondsman's Avatar
NCBondsman
The 07 street glide has the light behind the fender that shows through the slots. I just wired a led run/brake that has amber turns on a friends bike. Looks like this one. Don't know if this is the same one he has.
http://www.ebay.com/itm/Smoke-Tri-Ba...1db130&vxp=mtr
Old Feb 20, 2014 | 09:59 PM
jlj6t's Avatar
jlj6t
Ahhh...SG. Yeah, should've caught that little detail.
Old Feb 20, 2014 | 10:17 PM
NCBondsman's Avatar
NCBondsman
To wire in the one I did, it was three wires that go to the plug on the left side under the seat between the frame and fender (red, white, and black), then there were 2 wires (blue-right, yellow-left) that we soldered to the respective purple wires under the taillight that goto the turn signals.
Old Feb 20, 2014 | 10:46 PM
Bagger_Vance's Avatar
Bagger_Vance
Just bought this one off Amazon but haven't installed it yet and it looks like the same thing as above. I did hook it up to a 12V battery pack to make sure all the lights and signals worked. I'm not going to use the turn signals and just wanted it for a running and brake light.
Amazon.com: Harley Street Glide Tri-Bar LED AUX Brake Light +Signal: Automotive Amazon.com: Harley Street Glide Tri-Bar LED AUX Brake Light +Signal: Automotive
It's the right one for your 2007 and only $29.89 shipped.
Old Feb 20, 2014 | 10:49 PM
offthewall's Avatar
offthewall
Hey All, I need to replace the rear fender running light(bottom of fender) on my 07 streetglide (again) I seen there is an upgrade where this light can be upgraded to a run/brakelight. Anyone done this to their's and did you have any issues?
I did the HD kit. Super simple and one of those things that you wonder why the MoCo didn't do it as stock.
