I just installed my Andrews 57H cams. My front cylinder exhaust lifter wont bleed down. Its been about 2 hours and I still cant turn it with my fingers. The intake has bled down though. I have only adjusted the front cylinder, so not sure about the back lifters yet. Anyone ever had this? Should I just back it off a few flats until I can turn it with my fingers? I have them set at 20 flats (S&S adjustable push rods). Thats what they say will get me adjusted correctly. And Im sure Im on the base circle...I go to TDC on the compression stroke, then slightly past to be sure. Not sure what I should do here....anyone??
Why did you go slightly past TDC? I've always gone to TDC and left it (I use a long plastic drinking straw to double check).
Completely collapsed the push rods are slightly different lengths. The longer rod is the exhaust rod. Doubt that is your problem since the exhaust side is giving you problems, but just thought I would throw it out there.
I'd try backing it off a couple of flats to see what happens.
I have the same question as Biggzed...why did you go past TDC? Use a straw and find true TDC and adjust from there. When you say slightly past, just how far?
I've had my Woods lifters take about an hour to bleed, but never 2 hours.
The lobes on the cams are "flat" for the majority of the bottom part of the cam. That was what a HD mechanic said anyway. Thats what it does. The base circle goes on for a few degrees. It dont have to be exactly at TDC, this way is just extra measure to be sure.
Anyway, I have rocked it back and forth, it dont loosen up any.
Agreed, that is why I asked how far past you went. Given you only went "slightly" past I would back the push rod off and go thru the adjustment again.
Past TDC a degree or two. The piston may drop 1/8" maybe. That dont explain why the intake bled down though. I backed off one flat and was able to turn it.
Sounds like it was already bled down during the initial preload. In other words, no initial oil was in it to begin with for whatever reason. By turning it the 20 flats it just stayed bottomed out, valve stays open, nothing there to bleed down. perhaps remove lifter, pre-oil in a can full of oil again and retry?
Even if the lifter had no oil in it you should be able to make your adjustment after zero lash.
At 20 flats the lifter is just past 50% of it total travel, so its not bottomed out. I have had some lifters take several hours to bleed down, others in 15 minutes. Cant explain why. If you are sure you were on the base circle and you counted your flats correctly, then leave it another while. If it still doesn't bleed down, back it off all the way, double check you are on TDC and set it again.
