Clutch Cable Help
Old Feb 26, 2014 | 08:20 AM
zdrifter's Avatar
zdrifter
Default Clutch Cable Help
Never been able to understand why my '12 RKC clutch cable rattles against the crash bar, so I took a look at the manual. (RTFM, right?)
The routing diagram shows the cable through a 'P' clamp on the left side top of fork. The hole in the 'P' faces aft in the diagram and is on wrong on my bike ('P' is forward).
So the question for anyone is ... if the cable is freed at the clutch lever will the 'eye' pass through the 'P' clamp so I can reverse it.
Thought I would ask before doing, guess I could just do it and see but asking is good, right?
Otherwise going to have to pull the whole cable just because someone at the factory or dealer had a bad day.
Thanks in advance for your help.
Old Feb 26, 2014 | 08:26 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Undo the bolt holding the clamp. Remove clamp. Reverse position. Reinstall clamp.
It's quicker and easier than removing the cable.
Mine is also zip tied to the frame (I think). Zip ties can fix many ails.
Old Feb 26, 2014 | 08:59 AM
hobobiker's Avatar
hobobiker
+1 on what was said above. You can even get fancy colored or chrome zip ties as well if you don't like my favorite color...black.
Old Feb 27, 2014 | 09:35 AM
zdrifter's Avatar
zdrifter
Thanks for the help guys!!!
Didn't realize the clamp opened up, didn't look closely but now see it's an easy fix ... Cheers
DynaJ
May 9, 2012 06:41 PM
2010IRON883
Jun 22, 2011 12:27 PM
2010IRON883
May 25, 2011 05:42 AM
harris48cars
Jul 24, 2008 03:58 PM
BruceHarrisJr
EVO
Dec 12, 2007 09:20 PM
