Dimple drain plug?
Old Mar 2, 2014 | 10:24 PM
Bill03E's Avatar
Bill03E
The biggest reason for me to get them on my bike,is that the HD plugs suck, the magnets tend to fall out, an the HD ones are not 1/4 as strong as the dimple.
Old Mar 2, 2014 | 10:39 PM
piesik650's Avatar
piesik650
Originally Posted by soos
Aren't magnetic drain plugs meant to be removed and cleaned occasionally?
Atleast someone caught on. that plug isn't bad to remove its just the guy that is removing it you have to worry about. once every 5k I pull it. and I change all my fluids every 2500 or when I get home from a trip that is longer then that.
Old Mar 2, 2014 | 10:44 PM
Juan L's Avatar
Juan L
Moderator
Keep flaunting certain disaster!
I think I'll get some of those plugs to try. I saw some little pieces of gears on the tranny plug and maybe a stronger magnet will help it out.
Old Mar 2, 2014 | 11:26 PM
karbar99's Avatar
karbar99
I have them. No comparison to the stock plug magnet. Safer to say 100 times more the magnet pull, not 3, 4, 5 or 10.
Put one next to a 12in crescent (the magnet will pick up and hold it in the air) then try this with the stock magnet. :-) You'll then be a believer.
Old Mar 3, 2014 | 12:26 AM
RAP's Avatar
RAP
I have one on the oil drain, one on the tranny drain, and one on the primary drain. Could of bought a chrome du-dad with that money but I like the idea of protecting my motor as good as I can. These are a well made and powerful piece. But hey, that's just me.
Old Mar 3, 2014 | 05:15 AM
2009's Avatar
2009
Wouldn't there be a problem with picking up screws and nails off the roadway? :
Old Mar 3, 2014 | 06:59 AM
HDV-GLIDE's Avatar
HDV-GLIDE
Originally Posted by lionsm13
I got em. All 4.
A PM thing if nothing else.
Don't need no "O" rings with these neither.
I see o-rings on most of the plugs pictured on their webpage? I do like what I read but I said yesterday I was done buying things for the bike, what shall I do!!!!!!
Old Mar 3, 2014 | 07:36 AM
12hdrk's Avatar
12hdrk
Just beware that those magnets can alter the crank rotation and mess up timing. Unless you use Amsoil, which has antimagnetic properties to counteract the magnetic field.
Sent from my Galaxy Nexus
Old Mar 3, 2014 | 08:52 AM
Hell Fire Hog's Avatar
Hell Fire Hog
I seen a guy that had a man hole cover stuck to the bottom of his bike because of one of them drain plugs.
A guy tried riding over some railroad tracks and was thrown from the bike when it stopped suddenly.
Another person rode by a saw blade factory and..............well you can imagine what happened to him.
Old Mar 3, 2014 | 09:12 AM
Hoodooman's Avatar
Hoodooman
6th Gear
I put 5 in my bike and the engine would not turn over do to the strength of the magnets. I removed the magnets and the engine turned over. Those are really strong magnets! Ok to put 3 in and you will be ok
