SERT EFI Help!!!!
Old Mar 16, 2014 | 11:09 AM
peddler's Avatar
peddler
Originally Posted by ke5rbd
I didn't know that TTS had discontinued the upgrade. It has been in the last 4 or 5 months as got one near end of last year. I believe if I didn't have lots of experience with the old SERT that I wouldn't consider another tuner. I think they quit building them in 07. Maps will be hard to come by. the SEPST, PV, and TTS all work great and I am sure others do also just don't have first hand experience with others beside the PCV and PCIII.
Discontinued in December 2013 according to TTS.
Old Mar 16, 2014 | 12:03 PM
BLKPRLFLHTCU's Avatar
BLKPRLFLHTCU
Many years ago I bought a 232-usb adapter from the local computer shop and it has never given me any trouble, Windows will locate a driver for it its all good.
Old Mar 16, 2014 | 12:48 PM
peddler's Avatar
peddler
And used it to make changes to a Harley Davidson EFI with a SERT?
Just curious.
Old Mar 16, 2014 | 11:03 PM
ke5rbd's Avatar
ke5rbd
Thanks for the info. Won't being telling folks they can upgrade anymore. TTS is very good tuner and good canned maps.
Old Mar 17, 2014 | 12:35 AM
JayDRod's Avatar
JayDRod
I wouldn't stick to HD on this. I would go to www.dynojet.com with this question and see if they make a tuner that will work with your configuration.
Old Mar 18, 2014 | 06:26 AM
peddler's Avatar
peddler
Dynojet definitely makes a tuner for my bike. The tuner/SERT isn't the issue. In my case it would be a pc/cable issue. Harley never updated the SERT/PC cable to include a usb connector and the pc world has moved on from including serial ports.
If I was looking for a reason to spend another $400-500 to replace the SERT I'd definitely look at the Power Commander line. My understanding is Dynojet makes a fine product and they have moved on from the serial port to the usb port connectors.
Thanks for the suggestion.
Old Mar 31, 2014 | 09:28 PM
cutsforth693doa's Avatar
cutsforth693doa
2nd Gear
Default Cables
I also have that tuner. Just came with the bike I bought. I wanted to use it with Mytune to tune my bike but I don't have a cable to go from my tuner to my bike. Was wondering if the current cable they sell for the Street tuner and Super tuner would work.
Old Apr 1, 2014 | 08:08 PM
ke5rbd's Avatar
ke5rbd
They won't work. You need this cable kit. http://www.mastertune.net/harleydavidson.htm
The 2000006 USB to Serial adapter and 2000009 VCI to bike 4 pin for pre 14 touring.
I would call them to make sure you get the right one from VCI to bike unless sure which one. Some Dyna's and all 14's use 6 pin diagnostic plug. You can probably get the Usb to serial adapter at electronics outlet.
Old Apr 1, 2014 | 08:41 PM
wurk_truk's Avatar
wurk_truk
Folks that tune, will NOT use generic cables. Buy the TTS cables. Its way cheaper than trying to find the right drivers to talk to the ECM.
Belkin used to make a cable that worked, but they never updated the drivers. At least the TTS is a known to work solution.
Those that feel generics are the same and all cables work the same are sadly mistaken. It's actually difficult to get an out of the box cable to do duplex communications correctly.
I talk to PLCs and machines.... I still use a serial port laptop for most of that. I'm out of state, so I'm no help right now, but I just bought a cable for Win8 that actually works good our of the box from Amazon.
I've been doing this a bit... talking to aTTS product, use a TTS cable. How cheap does one have to be if they already own a bike?
For a new, blue, TTS, dealer cables work fine. Under $40 for both cables.
Toshiba still sells a serial port laptop that is NOT a "tuff" type laptop.
kingkingking
May 15, 2009 08:19 AM
kingkingking
May 14, 2009 11:20 PM
jsbridgew
May 16, 2008 10:08 AM
Ultra_Bob
Feb 10, 2008 07:17 PM
Hagar the Horrible
Mar 16, 2007 04:15 PM
