Adjustment? There is not one....all you do is just install the sensor. I would find a different dealer that said that.
It probably is just the sensor as it was common on certain models and is still pretty common. It could also be the idiot lights in the fairing just above the radio. I have seen some where the bulbs would vibrate just a little loose or have corrosion there....causing lights to come on or not come on while riding.
You can adjust them. A slight turn on them will change position, they do not seal out any high pressure. I put some teflon tape on threadson mine and tweaked it a little and cured problem with light. I have also seen some shops use thicker sealing washer to change position of sensor.
