Sealed vs Shielded Bearings
Old Mar 13, 2014 | 07:26 PM
Bruin08's Avatar
Bruin08
Default Sealed vs Shielded Bearings
2013 SG calls for sealed bearings, can you use shielded bearings or do they need to be sealed.
Old Mar 13, 2014 | 07:43 PM
Just Me's Avatar
Just Me
Whats the difference?
Old Mar 13, 2014 | 07:53 PM
soft 02's Avatar
soft 02
Either way you should pop the seals off the new ones and put some better grease in them.
Old Mar 13, 2014 | 07:57 PM
xpilot's Avatar
xpilot
Sealed means rubber or similar SEALS. Shielded has a metal shield, that will keep the bumble bees out. You will really want sealed, usually specified as a number plus 2RS. Meaning 2 rubber seals
Old Mar 13, 2014 | 08:00 PM
lt1-xjs's Avatar
lt1-xjs
A shielded bearing has metal shields to help hold the grease in but can still weep out and let moisture in. A sealed bearing has rubber coated shields to hold all grease in and keep all elements out. Use a 2 sided sealed bearing.
Old Mar 15, 2014 | 08:52 PM
Bruin08's Avatar
Bruin08
Gotcha, harley used the better bearing. I didnt get mine from harley though, I got some american made bearings.
Old Mar 15, 2014 | 11:23 PM
hover's Avatar
hover
If your talkin wheel bearings, then take them back and trade em in for sealed, both sides, usually designated 2RS on the end of part number...eg 6205-2RS
Almond farmer
Oct 3, 2017 04:43 AM
Almond farmer
Wheels/Tires
25
Aug 8, 2017 11:51 PM
sgt joseph
Aug 20, 2007 03:45 PM
ChrisB
Ironhead
Nov 15, 2006 02:52 AM
monster0826
Jun 5, 2006 02:24 AM
