25 mm wheel bearing change
The bearing has been superseded to p/n 9276B.
The "A" bearing incorporates a molded rubber seal.
The new "B" bearing uses a metal shield.
AST bearing company has a white paper publishers on the subject of bearing rubber seals and metal shields.
The "A" bearing uses a type 2RS rubber seal that creates drag between the inner and outer ring from friction.
The "B" bearing uses a type ZZ non removal pressed metal shield that creates zero drag between the inner and ring.
However, the "A" bearing with the rubber seal provides better protection in contaminated environments than the metal shield type.
Contacted four H-D local dealerships and none had the "A" version on the shelf and are now stocking the updated "B"" version.
This part must be a fast turn over item, since the updated version has been in affect since October of last year.
Must be an MPG thing or maybe a cost reduction measure.
The packing on both bearings say made in South Korea.
Any thoughts on the pros and cons of rubber sealed bearing vs metal shielded bearing.
the jury is still out on the metal ones but the timkins are a certified win. No if, ands, or buts...just win.
Sporty metals:
https://www.hdforums.com/forum/showp...&postcount=190
Self-inflicted Dyna bearing disaster:
https://www.hdforums.com/forum/showp...&postcount=462
Timkin 205pp:
http://Timken 205PP Ball Bearing, Do..._7nKByb22M1FR2
Fun times
Remember a conversion with an engr at Chicago Rawhide many years ago.
indicated if the sealing surface on the dynamic rubber seal was too smooth, the rubber would over heat and fail. BunaN is good to 240F.
Have placed a wheel hub in the kitchen oven at 220F to expand aluminum to remove stubborn sealed hub ball bearing.
Geeting a single rubber sealed ball bearing at a specialized bearing retailer based on the bearing # is an option, and by pass H-D
However, really bummed out that H-D changed the bearing from rubber seal to metal jacket that allows much more road dust to enter bearing.
Getting a single rubber sealed ball bearing at a specialized bearing retailer based on the bearing # is an option, and by pass H-D
There is a measurable amount drag on the 25mm ball bearing with rubber seal times four bearings adds up.
i only used the metal ones to test them out. I would have used timkin otherwise. The hd rubber/plastic ones were trash to begin with. You come out on top with the german timkins.
Still would vote for a good quality SKF ball bearing over a tapered roller bearing, no preload, pre lubricated, less rolling resistance.
http://www.surdyke.com
https://shop.newcastlehd.com
http://www.boardtrackerharleyonline.com
they may still have some on hand.
Ordered a rubber sealed Timken 205PP on Amazon today.
