Dyna Beads......
Old Mar 14, 2014 | 04:24 AM
Turret_plug's Avatar
Turret_plug
Default Dyna Beads......
His may have been beaten into the ground by now, but my new wheels give me a pretty good jiggle. I'm running a 21/18 mammoth spoke setup with a 120/70-21 front, and 180/50-18 rear. Between 30-55 mph...... It's hoppy. The wheels are holding correct pressure, and I see no external balancing, they were true when I installed them meaning when I spun them,they didn't seem to get caught on any real heavy spots, and didn't wobble side to side.......
I think I just have no balancing as I bought from a second rate seller. Are dyna beads my ticket to a smoother ride? The research I've done points to 1oz front, and 2 oz rear. Has anyone used these, how were your results?
Old Mar 14, 2014 | 04:27 AM
luc.who's Avatar
luc.who
Yes I have used them for the past 2 years and they have worked fine for me.
Old Mar 14, 2014 | 04:38 AM
Turret_plug
Did you use the dyna beads brand (ceramic) , or another brand (stainless)...... Just looking for the best first time result. They seem inexpensive, so I figured they're worth a shot, and simple to install. I just don't want to look at balancing weights on my custom wheels..... Ya know?
Old Mar 14, 2014 | 04:47 AM
Notgrownup's Avatar
Notgrownup
Turret Plug, i have used both dyna beads and now use ride on balancing and sealing gel and i see now performance difference with both, the added benefit of puncture sealing on the gel is what sold me.
Old Mar 14, 2014 | 04:53 AM
Turret_plug
Anyone else..... I got 2 yes's so far...... Need some more confidence boosting! Let me clarify some things, I'm not a dummy or a noob..... I got ripped off when I bought my wheels, got a good price, just not everything I paid for, which was balancing. I'm just looks for some forum wisdom......
You guys are like the Harley Jedi's........
Old Mar 14, 2014 | 04:58 AM
Notgrownup's Avatar
Notgrownup
TIP..if you have a compressor...when you are pouring either the dyna beads or the gel, blow a bit or air to clear the passage if it gets clogged. Go ahead and order it and use it...Tons of folks use it....You will be happy with either. I use to buy the beads 6 bags at the time...
Old Mar 14, 2014 | 05:02 AM
Turret_plug
Ok...... I'm planning on the beads, but certainly open to as many suggestions as possible
Old Mar 14, 2014 | 05:12 AM
Notgrownup's Avatar
Notgrownup
Here is the inside of my front EIII after over 30000 miles with dyna beads...The inside of the tire looks like a snakeskin but you can see the smooth streak in the middle..hope it helps... This is not bad for 30k...Gel doesn't do that...
Attached Thumbnails Dyna Beads......-dynabeadseffect2.jpg   Dyna Beads......-dynabeadseffect1.jpg
Old Mar 14, 2014 | 05:16 AM
Kesean's Avatar
Kesean
Have you thought about Ride On? I have used it on my Limited and my SG with no issues.
Old Mar 14, 2014 | 05:21 AM
Turret_plug
Are they beads, gel...... ?
