Charging/electrical Issues
Old Mar 15, 2014 | 01:46 PM
Jeff Vorhies's Avatar
Jeff Vorhies
Default Charging/electrical Issues
Was out for a ride today and developed an electrical or charging issue. I noticed the voltage gauge had dropped to around 11 volts.
I know my battery is getting weak, I have a new one ordered that will be here Monday.
Could it be the battery died, or did my voltage regulator go out(I put a new one on the bike about a year and a half ago), or could it be the stator?
Any/all information and advice is appreciated.
Old Mar 15, 2014 | 01:50 PM
mkguitar's Avatar
mkguitar
jeff,
the diagnostic procedures have been posted 933 times, you can check the tech board; electrical
all you need is a voltmeter and the instructions.
ANY part of the charging system ( including the cables) which fails, can take out other components. Failing battery can take out the charging system too. can but not always, depends on the load a failing battery is putting on the system.
here is a link to a thread i started about $1300 spent on repairs, when the fault was a $12 cable:
https://www.hdforums.com/forum/touri...cable-pic.html
in future, the voltmeter in the dash is subject to inaccurate readings.
confirm observations at the battery...if you have a tender plug, you can meter there without lifting the seat
mike
Old Mar 15, 2014 | 01:51 PM
Jeff Vorhies
Originally Posted by mkguitar
jeff,
confirm observations at the battery...if you have a tender plug, you can meter there without lifting teh seat
mike
Thanks, I didn't think to look there. Was bummed my ride was cut short so I came home and pouted.........
Old Mar 15, 2014 | 03:37 PM
doc ock's Avatar
doc ock
Before you replace anything check all the connection associated with the problem. Check battery ground, regulator, stator, ect. Clean all connections and use some dielectric grease. I had the same symptoms, turned out to be loose battery ground cable.
Old Mar 15, 2014 | 04:07 PM
69cj's Avatar
69cj
I just replaced my voltage regulator. It was intermittant. Remove the voltage regulator from the bike. Start the bike and take your dvm and check the voltage on the stator plug. Put the voltage on ac volts for this test. You should have app. 20 vac pin to pin on all three pins. This is ac 3 phase power. If you have the voltage there then it will be the voltage regulator going bad. The stator consists of wire type windings and is either good or bad. The regulator consists of diode bridges which can be self healing thus the intermittant problems. Hope I was clear in my description. This is also dependant on you having a good battery and no shorts or grounds.
alee18
Electrical/Lighting/Alarm
Jan 8, 2018 01:34 PM
nobody05
Sep 21, 2016 08:26 PM
adamk
11
Mar 31, 2015 04:22 AM
streetglide28
May 1, 2011 10:44 PM
magflh
EVO
Jul 20, 2009 07:44 PM
