Hello ill start by saying I have a 2004 road king and 2004 fatboy. I purchased both within a week... Fatboy Runs awesome but double the miles compared to the road king. the road king has 7000. Any way with the road king I have the most hated electrical short I believe. I have been trying to figure this out for a week now and no real luck, after reading a few threads no one really had all of the same issues... SO now to what the bike is doing. I went to go take it for a ride and noticed that I had no turn signals in the rear and no accessory. Pulled it apart and the fuse was blown, So i put a new one in pressed the trip switch and the acc fuse blew.. So thinking it could be in that area I pulled it all off the tank inspected nothing found.. Put a fuse back in the acc spot turned the bike on had blinkers and everything worked took it down the road... blew a fuse again with out using the blinkers or the trip button.. So i pulled the seat off checked the wiring going to the rear fender the housing around the wires and wires were bent a little so I inspected all of that and plugged all the wiring back into the connecters, put a new fuse in and started it then it blew again shortly after running. So I started with this issue thinking that it was the trip button because i could press it and the fuse would blow but now pressing it doesnt blow the fuse.. Kind of stuck the local Harley wants 100$ for diag plus hourly what it takes them to find it. Maybe some on here has a direction for me to look at next.
Troll 1st post and he starts bitchin no hello I'm new to the forum, no just starts bitchin right from the get go. I think you joined the forum for the wrong reasons you would be better off talking to the wall, BS
Did you check the wires in the fender? You would have to pull the wheel. The
come lose sometimes and get eaten by the rear tire.
He just asked a question. Most people that ride just ride...They don't play on the internet and never even think about a forum until they have an issue...He isn't beating up our beloved Harley (sarcasm)...He is just trying to fix his bike without paying the dealer...I don't blame him at all...
Edited to add...This forum was a lot better a few years ago before all the negative douche bags showed up...Maybe they were always here but I didn't notice them as much???
If you suspect the trip switch, replace it. It is cheap from the dealer. I think under $20? Mine was worn out and would erase the trip mileage if I flipped between that and the odometer. However I think you might have a pinched wire somewhere. I had one in my taillight that kept blowing the headlamp fuse.
Post #1 sounds like a guy with a weird electical problem.
Post #2 sounds like BITCHING.
someone **** in your Chereos this morning?
Etherbike, is it possible to unplug the rear light harness, take it for a ride in a safe place(with no rear lights) and see if the fuse still blows?
If it doesn't, it should be isolated to somewhere in that harness.
There is probably one little nick or chaff in a wire shorting on some sharp edge somewhere.
Look inside the light housings.
You need to be looking for something going to ground...shorting out. As mentioned, under the fender is the most obvious place to start.
You have a 10 year old machine. With no history on how or where it was ridden before you bought it, all kinds of gremlins could be lurking. Start with a service manual. If you plan on doing most of the work yourself, it will be money well spent.
Good luck and give that bike a good check over before venturing too far with it. Nothing more distracting and dangerous than trying to diagnosis a rolling vehicle of any kind. Especially a motorcycle.
F***in idiot... Ban this d-bag.
Anyhow, tell us about the bike. Stock bars and controls? What aftermarket stuff do you have on it? Oem lighting? Etcetera...
There's a reason HD charges $100 an hour for trouble shooting... Shorts can be tricky and finding them through a forum can be near impossible unless someone with a RK has/had the same problem.
