Most MC floating rotors are really semi-floaters as the outer disk is almost bolted solid to the carrier with stainless steel rivets. My HD ones are anyway.
True full-floaters move on the carriers (so much so that they can rattle), allowing them to self-center in the caliper for reduced brake drag and will float during repeated thermal cycling.
They ARE true floaters. As soon as they warm up they can move around, in the way you describe. Early floating rotors rattled for a couple of reasons - they were developed for racing, where noise doesn't matter and improved understanding of their benefits, plus changes in manufacturing techniques, have reduced what many would regard as undesirable rattle. Left long enough in service I'm sure a knackered set of H-D floaters will develop a rattle!
The other main benefit of floaters is reduced heat sink into the hub and hence wheel bearings.
The primary point of floating discs are to compensate for fixed (non-floating) calipers. The result being more even pressure and therefore better braking force and more even heating.
The secondary benefit, as grbrown pointed out, is reduced heat transfer to the wheel bearing via the hub. The down side to this is increased rotor heat, which increases fade and counteracts the anti-warping benefit of a floating rotor.
