Checking air pressure
Old Mar 24, 2014 | 11:51 AM
Hausguy's Avatar
Hausguy
Kurveygirl for me too. I have the Knuckles wheels and it's all good.
Old Mar 24, 2014 | 11:57 AM
ElectraGlideSteve's Avatar
ElectraGlideSteve
Originally Posted by RKZen
I use one of these. Not sure what the part # is, but I got it at the HD dealer. Works pretty good and no loss of air.
Yup, here it is here:
http://www.harley-davidson.com/store...stem-extension
Bought one last week at the dealer and it works really well for an $11 solution.
Old Mar 24, 2014 | 12:04 PM
bigheadted's Avatar
bigheadted
Think about all the hours in R&D and no change was made to make this vital process simpler. What would a angled stem cost versus a straight one? A few pennies?
How many of you bypass frequent air pressure checks because of this crappy setup?
The tire manufacturers are in cahoots with Harley to ensure tires wear out as fast as possible so they can sell more and make more labor money ! And to sell 11 dollar extensions too ! It is a conspiracy I am telling you !!
Old Mar 24, 2014 | 12:08 PM
1st 96 ultra's Avatar
1st 96 ultra
I think the HD hose extension with a 90% extension would work great , then take the extension off when done , the hardest part of putting air in my tires is finding the darn stem to me , how about a bright orange stem so they can be found easier
Old Mar 24, 2014 | 12:12 PM
Hausguy's Avatar
Hausguy
Mine have a small white mark on the tire where the stem is located. Easy to find.
Old Mar 24, 2014 | 12:19 PM
1st 96 ultra
dam , that might be my next mod , cheap to
Old Mar 24, 2014 | 12:43 PM
Tanker2's Avatar
Tanker2
I tried a number of things. Here is my cheap solution. I found a little short air gauge at Wally World. It's about 3" long. 2 bucks. It's the type with a stem that moves in and out. It's short enough to fit up under the rotor. Just carefully push it on to check air and be careful not bump the stem when you remove it to read it. Works good. Also have a shortest air chuck I could find to add air. I also pull on the valve stem and bend it towards outside of rim to add air on front tire. But your all right. What a pain in the a$$.
Looks like just installing the Harley extension is more trouble then it's worth as tight as those spokes are together. IMO
Old Mar 24, 2014 | 04:48 PM
bigdaddy33's Avatar
bigdaddy33
Angled tire valves make a pain in the *** job a bit easier.
Old Mar 24, 2014 | 04:57 PM
bigheadted's Avatar
bigheadted
The first time I went to check air on my Dad's Ultra I was like you gotta be joking ? What a bunch of idiots who ever let this stupid design hit production. It is enough of a hassle just to get that low to the ground to check rear tires anyhow, I have a small carpet just for this purpose, I get the air hose and gauge and lay down on the job !
Old Mar 24, 2014 | 05:06 PM
roadking2014's Avatar
roadking2014
bout every two weeks I raise mine up on my lift, take off the saddle bag, sit on my stool and check the air pressure and add if even necessary. Pretty much stays at 40 and 36. Do I check mine while out on the road in a gravel parking lot. No! If the riding characteristics haven't changed, and you'll notice if you have low pressure, I dont worry bout it. I asked a Michelin engineer that was at a bike rally about angled valve stems and his response was. "valve coudée tiges sont de la merde".
