The first time I went to check air on my Dad's Ultra I was like you gotta be joking ? What a bunch of idiots who ever let this stupid design hit production. It is enough of a hassle just to get that low to the ground to check rear tires anyhow, I have a small carpet just for this purpose, I get the air hose and gauge and lay down on the job !
I pull onto my lift because Im to old and stiff to check on ground, only do that when Im on the road and agree the whole process is a pain in the butt and almost always scrape a knuckle in the process.
So curse myself every time I remember that I forgot to add 90" stems when I bought new tires. Did the back first....forgot. The next year I did the front.....forgot again.....dumba$%
Cut out every 7th spoke,starting with one next to the air valve. Smooth/blend the cut. Plate,paint or powder coat to your preference. You now have a functional,custom wheel!
bout every two weeks I raise mine up on my lift, take off the saddle bag, sit on my stool and check the air pressure and add if even necessary. Pretty much stays at 40 and 36. Do I check mine while out on the road in a gravel parking lot. No! If the riding characteristics haven't changed, and you'll notice if you have low pressure, I dont worry bout it. I asked a Michelin engineer that was at a bike rally about angled valve stems and his response was. "valve coudée tiges sont de la merde".
