Tie down
any dealer has them...i just put these on my 14 and fit well, barely noticable and work MUCH better than bar straps.....do it.
Also, if you don't have one it's a good idea to get a wheel chock to keep 'er from tipping on you. I use one of these HF specials when hauling in the pickup. Low budget and works great. I move it from trailer to truck as needed. http://www.harborfreight.com/motorcy...l#.UzQm5F6Br_w
I like the idea of the HD tie down kit, but it looks like I need the other part #93500011 for my '14 Street Glide.
On the rear, I use two tie downs around the rear wheel pulling outward so the bike doesn't move side to side.
I have a set on my Limited, and put a set on the SGS.
Personally, I would NOT tie to bars or the fork/fender connection, bars are mounted in bushings, and pulling on the bottom of the forks you are pulling on the axle....
The 14s are tricky to get to the triple trees, ABS wires and brake lines are fastened down where you need to wrap a softie, and I'm afraid to pinch those.
My 2 cents.
Decided against using the handlebars due to the faring and the turn signals. No real way to route the straps without hitting things. Decided to go with the tie downs fro HD. The put the attachment point below the turn signal so the straps have a clear shot down to the hooks on the floor. I also tie the back down to stop side to side motion. I plan on using the saddle bag supports, since there is not a lot of tension on that set of straps. Just enough to stop the bike from sliding side to side.
Here is the link to the HD chrome tie downs for the 14 SG. Part number 93500011
http://www.harley-davidson.com/store...-brackets#tabs
But I've got to tack another $7 for the lowest cost shipping, so it's not that big a deal to buy them on my trip.
My 2 cents.
Oh, with the HD brackets above, you are compressing the front forks when you tie down to your mounting points.
