Rear rotor torx replacement
Old Mar 28, 2014 | 10:40 AM
kishstl's Avatar
kishstl
Default Rear rotor torx replacement
Had a b**ch of a time removing the torx bolts off my rear rotor. Ruined one torx socket and took 2hrs. Anyone know the size and thread so I can get some different head grade 8 bolts for that moronic torx.Thanks!!!!( I posted this in wheels tires too but more folks usually on this forum)
Old Mar 28, 2014 | 10:42 AM
fox2boost's Avatar
fox2boost
Harley recommends changing them every time i would go to the stealer
Old Mar 28, 2014 | 10:44 AM
Joe12RK's Avatar
Joe12RK
the original ones are grade 8 - next time use one of those hammer impact drivers. mine came off in 5 min. joe
Old Mar 28, 2014 | 10:55 AM
Uncle Larry's Avatar
Uncle Larry
Good advice here.
Old Mar 28, 2014 | 11:09 AM
Beav's Avatar
Beav
Is it ok to reuse the originals after chasing the threads etc.....????
Old Mar 28, 2014 | 11:11 AM
bagman1's Avatar
bagman1
First off be sure you use a good quality bit. Snap On has the best and I have tried them all. Trust me on this one. The lock patch they use is equilelant to red locktite which most of the time requires heat before you remove them. Another trick is to use a long handled ratchet on your bit socket, it will give more leverage and a smoother pull on the bolt.
Old Mar 28, 2014 | 11:17 AM
kishstl's Avatar
kishstl
Thanks for the responses. I did use impact socket. I did heat tnem up and I will be purchasing a snap on socket. I will not reuse torx bolts there. So......does anyone know the size and thread for those?
Thanks again.
Old Mar 28, 2014 | 11:24 AM
voodoodrug's Avatar
voodoodrug
drilling them first works for me. The drill bit sits nice and centered on the bolt the way its shaped.
Old Mar 28, 2014 | 11:32 AM
103 sedona orange's Avatar
103 sedona orange
You have the old bolts you took out? Just take them with you when you get new bolts.
Old Mar 28, 2014 | 11:41 AM
skratch's Avatar
skratch
teach a man to fish.......
http://www.granitestateharleystore.c...c%7e1OF2%5cKBM
3/8-16 x 1
i don't usually have too much of a problem if i heat them up enough. i use a heat shrink air gun and when i think i've heated it up enough, i do an extra 15 seconds or so. without heat, i've broken torx bits. with heat, they come right out with a breaker bar.
