transmission dip stick
Old Apr 2, 2014 | 07:07 PM
josame's Avatar
josame
It's not the easiest thing to get started thats for sure.
Old Apr 2, 2014 | 07:15 PM
Drat's Avatar
Drat
I must be doing something wrong because mine always goes in easy......
Old Apr 2, 2014 | 11:00 PM
teedub79's Avatar
teedub79
Yea on my dyna goes in and out no problem but on my electra glide its a pain in the ***... I ordered a new dipstick just in case
Old Apr 3, 2014 | 12:09 AM
dickey's Avatar
dickey
I don't have any problems sticking my dipstick into the hole. The lube makes it real easy; just go gentle & don't put too much force behind it and it should slip in nice & smooth. And make sure you don't stick it in the wrong hole, or there will be leakage. Not to mention dirt on your dipstick.
Old Apr 3, 2014 | 12:39 AM
Hell Fire Hog's Avatar
Hell Fire Hog
My pecker pounders are fairly fat so getting them into complex areas can be challenging some times. However I use my bare hand to get my dipstick aligned just right before I screw it into the hole it was intended to fit into. You should be able to wiggle it and turn it a little bit before you feel it slip into place. A little bit of lubrication will allow the O-ring at the top to seal perfectly when its in all the way.
Old Apr 3, 2014 | 12:56 AM
Hell Fire Hog
Also I should mention that after you have put your dipstick in the hole many times, over the years, the hole will become enlarged. After several years of putting your dipstick into the hole it will get quite loose and youll completely forget about all the problems you had getting it in when it was new.
Old Apr 3, 2014 | 09:38 AM
teedub79's Avatar
teedub79
I used the my t handle ball end and went right in...hmmm problem solved and thanks for all the sex refrences...lol
Old Apr 3, 2014 | 10:05 AM
Def Mute's Avatar
Def Mute
The dipstick holding the fluid level indicator is usually the cause of difficulty...
jpooch00
2014-2024 Touring Models
52
Nov 9, 2017 07:08 AM
alcapone
Oil Archive (no new posts)
Sep 19, 2017 12:31 PM
Gannicus
Audio Systems
Nov 10, 2015 09:23 AM
Taterdog
Jul 15, 2008 11:31 PM
Mnhorsemom
Nov 16, 2006 09:42 AM
