Tips for NOT getting oil all over engine?
Old Apr 2, 2014 | 03:28 PM
ybnorml's Avatar
ybnorml
Knock a hole in the top then rotate 180 degrees so it's on the bottom,
then knock another hole at the top for a vent.
I use the cut / split plastic soda bottle under the filter also.
Old Apr 2, 2014 | 04:02 PM
rbferg's Avatar
rbferg
I've found the H-D catch funnel to be pretty much worthless if you have a oil cooler. It's to thick and there's just not enough room. I have used the two liter bottle trick with "some" success.
Old Apr 2, 2014 | 04:23 PM
ISLANDER1089's Avatar
ISLANDER1089
There's some great information here, so thanks for contributing. Does anyone use a vacuum device to suck the oil out of the crankcase?
Old Apr 2, 2014 | 04:40 PM
bikergal's Avatar
bikergal
I read somewhere on HD forums about cutting a milk half gallon plastic container length wise while leaving enough carton to catch the oil. Maybe someone can find the link to it. I will be using this method when I do my first oil change.
Old Apr 2, 2014 | 04:43 PM
Hausguy's Avatar
Hausguy
You only spill about 2% that way.
Old Apr 2, 2014 | 04:48 PM
fourburgs's Avatar
fourburgs
Just pull the filter and spray the area down with brake cleaner to clean up the oil..
Old Apr 2, 2014 | 05:01 PM
Fatboy Brian's Avatar
Fatboy Brian
I use a long bent piece of cardboard cut from a old box and stuff a rag down on top of the motor mount. I learned that little trick from Schumacher on the forum. Last time I didn't spill a drop.
Old Apr 2, 2014 | 05:07 PM
03snake's Avatar
03snake
Brake clean works great for this, it is your friend. I do use the Harley orange drain thing. I also use the 'Scavenger' system after. I'll post my review of this system soon. I was a skeptic but now I'm totally sold. You can judge from my upcoming review.
After all this mess with a towel under the bike brake clean makes the residual mess all go away. (I wash the towels when my wife's not home.....)
Old Apr 2, 2014 | 05:43 PM
69cj's Avatar
69cj
The reason I just use the brake cleaner and then hose it down is because I also have an oil cooler and none of the other suggestions, as good as they may be, has worked for me. I still had a mess.
Old Apr 2, 2014 | 06:19 PM
Wander's Avatar
Wander
