seat compatibility
Old Apr 6, 2014 | 11:36 AM
pitarobb's Avatar
pitarobb
1st Gear
Default seat compatibility
I just purchased an '02 ElectaGlide Ultra Classic and will be getting a kit to easily remove the TourPak.
My next plan of action is to get a more appropriate seat. I read that a StreetGlide seat should do the trick nicely. I just wasn't sure what years/range would be compatible ?
Thanks in advance !
Old Apr 6, 2014 | 11:40 AM
Veekness's Avatar
Veekness
2006 and 2007 FLHX seats would be the only ones fit your frame...seat mounts changed in 2008, I believe...If I recall, the whole frame changed in what? 2009? Others will weigh in no doubt. I just found those two years of seat fit my 2006 Street Glide, and I wound up putting on a seat from a 2002 Road King for two-up riding.
Old Apr 6, 2014 | 03:42 PM
jus2anoyu's Avatar
jus2anoyu
97-07 seats will fit, except for the road king and street glide (and cvo Electra 04-05) due to the length of the tank console. The Electra, classic, and ultra have a short console and long nosed seat, the others have a long console and short nosed seat. Street glide is the same as the road king, a no fit for your early Electra.
Old Apr 6, 2014 | 06:18 PM
lt1-xjs's Avatar
lt1-xjs
I run a '07 Street glide seat along with the longer console. You can buy a console extension or swap it out.
Old Mar 25, 2020 | 11:49 AM
Lisa Schnorr's Avatar
Lisa Schnorr
Stage II
Will a 2019 roadglide seat fit a 2017 roadglide?
Old Mar 25, 2020 | 11:50 AM
Red's Avatar
Red
Yes..
Old Mar 25, 2020 | 03:40 PM
Essthreetee's Avatar
Essthreetee
I have a console extension sitting around doing nothing if you need one.
Old Mar 25, 2020 | 07:02 PM
Lisa Schnorr
Stage II
it was a question for another. Thank you for the offer.
Old Mar 25, 2020 | 09:54 PM
Essthreetee
Well actually the offer was for the OP @pitarobb as the spacer is for the old frame/tank/seat/console. I used it on my ‘07 ultra when I put on a short nose solo seat. Anyway, I have one sitting here if someone needs it. Chrome is excellent. No marks.
Old Apr 7, 2020 | 01:15 PM
BeardedSinner's Avatar
BeardedSinner
3rd Gear
So what I’m seeing here is that a newer (say ‘09-‘16) SG seat would not fit my ‘05 EG?
