Head light Blown need to get home!
Old Apr 10, 2014 | 10:52 AM
hdbob2006's Avatar
hdbob2006
Take the fairing off?? Just take one screw out of the bottom of the headlight ring,take ring off,and remove 3 retainer screws from retainer ring. [assuming you have a batwing fairing ?]
Old Apr 10, 2014 | 10:54 AM
jeffreydsilver's Avatar
jeffreydsilver
A H4 bulb is the same as a 9003 bulb. All auto parts stores have them!
Old Apr 10, 2014 | 11:59 AM
rbferg's Avatar
rbferg
Originally Posted by foxtrapper
To answer your original question, any H4 bulb will fit.
Inspect the bulb connector and smear a little dielectric grease in the connector while you have it apart. It helps allot with future removal.
Old Apr 10, 2014 | 08:15 PM
RickK's Avatar
RickK
Tonight I checked the connector and it looks brand new. No signs of heat or smells of burnt wires. The bulb was blown on low and high beam. It was a Osram Bilux 60/55 installed in a Hella E code H4. Im not sure why the low beam blew and then when I flipped it to high it blew right away. IMO if its possiable, the low beam fillament might have landed across the high beam and caused it to short when I flipped it on.
I doubt this had anything to do with it, but when I tried to start it this morning before it blew, the security did not detect my fob in my pocket and I attempted to start it . I noticed the flashers begin flashing so I turned the ign off grabbed my other fob and tried it again. When I turned it on to try to start it ,the low beam never came on, it was blown .
I installed a Silverstar Ultimate for now until I get time to order another one.
Thanks
Rick
a99miata
Apr 23, 2014 10:39 PM
Swamp-Rat
Oct 31, 2010 08:25 PM
CaptnAl
Aug 20, 2007 10:25 AM
LT753
General Topics/Tech Tips
Apr 20, 2006 12:06 PM
KenM
Mar 26, 2006 03:00 PM
