Hand grip install Question
Old Apr 10, 2014 | 03:06 PM
KCFLHRC's Avatar
KCFLHRC
Originally Posted by last12know
i used the get a grips.. so i think your rite..
for what it's worth i really like the grips.. nice not having tacky hands at end of day..
They are nice grips, very comfortable.
Old Apr 10, 2014 | 03:15 PM
RollaMo's Avatar
RollaMo
Originally Posted by Mac daddy 103
Sorry peeps, this is for a 13 SG.
No Glue required for that bike.
Old Apr 10, 2014 | 05:35 PM
Mac daddy 103's Avatar
Mac daddy 103
Thanks for the input guys, I will tackle it tomorrow as I need a 27 torx I got the 25
Old Apr 10, 2014 | 06:30 PM
03snake's Avatar
03snake
'13 SG. Installed 'HD Get a Grip'. No glue required. I had to cut off the left grip with a knife and sand the glue down to install the left grip. When you install the right grip make sure you have a little left to right play in the grip before tightening. Otherwise e grip will be jammed up against the end of bar.
Old Apr 10, 2014 | 07:10 PM
rockajet1's Avatar
rockajet1
Originally Posted by Gunnysgt
If it's a Harley grip, No it won't freakin spin if you don't put glue on it. The newer bikes have a large tab on the left grip to fit into the slot on the switch housing. Never glued one never had to , glueing the grips is from way back when.... There may be some aftermarket grips that don't have that tab, in that case they usually come with their own adhesive.
Old Apr 10, 2014 | 07:21 PM
dickey's Avatar
dickey
When you buy the grips, if there is a long Q-tip in the package, you need glue. No Q-tip...no glue.
Old Apr 10, 2014 | 08:58 PM
Wander's Avatar
Wander
Don't forget to put a Popsicle stick or some cardboard under the end of your brake lever.
Old Apr 11, 2014 | 02:01 AM
Smash's Avatar
Smash
Can you elaborate on this? That's the second time I've read the Popsicle stick referenced on this board and I don't know what it's for. I'm putting grips on my '13 SG when I get home from this deployment and I'm curious about the Popsicle stick.
Old Apr 11, 2014 | 05:53 AM
Wander's Avatar
Wander
Get Popsicle from freezer. Eat one 1/2 of Popsicle. squeeze the brake lever and create a gap between lever and housing on the brake reservoir end. Slide the Popsicle stick into that gap so the brake lever isn't allowed to fully close upon release. Proceed with loosening the switch clamshell etc and installing the grip. After grip install and everything is buttoned back up squeeze brake lever, pull Popsicle stick and release lever. Finish other 1/2 of Popsicle before it completely melts. Tackle the right side grip if not already complete. Wash Popsicle down with tasty cold beverage.
It's possible to break the brake light switch in the housing if the lever isn't partially squeezed thus the need for this step. Some grip kits come with a spacer but a Popsicle stick works fine.
Old Apr 11, 2014 | 06:02 AM
Mac daddy 103
It's so that you don't damage the brake light switch.
