Hand grip install Question
Old Apr 10, 2014 | 02:12 PM
Mac daddy 103's Avatar
Mac daddy 103
Default Hand grip install Question
Im installing new HD hand grips, Just want to know if the left side hand grip requires glue?. Thanks
Old Apr 10, 2014 | 02:14 PM
TWIN CAM 96's Avatar
TWIN CAM 96
Yes got to have some good glue to put her back on
Old Apr 10, 2014 | 02:20 PM
last12know's Avatar
last12know
don't believe i did for my streetglide.. the collar locked in place when switch housing put on.
Old Apr 10, 2014 | 02:25 PM
Mac daddy 103
Sorry peeps, this is for a 13 SG.
Old Apr 10, 2014 | 02:26 PM
TWIN CAM 96
Got to have the adhesive or the grip just spins around but do what you think is right.
Old Apr 10, 2014 | 02:29 PM
DPete's Avatar
DPete
Depends on the grips, some lock on as mentioned above
Old Apr 10, 2014 | 02:35 PM
KCFLHRC's Avatar
KCFLHRC
Yep, depends on the grip. The "Get A Grip" HD one's did not require any glue if I remember right. However, the instructions will tell you if needed or not. Some actually use hair spray for the adhesive if needed.
Old Apr 10, 2014 | 02:38 PM
thebackupninja's Avatar
thebackupninja
Yep... I just replaced the grips on my '14 SGS and no adhesive required. Oh there were HD grips as well.
Old Apr 10, 2014 | 02:39 PM
Gunnysgt's Avatar
Gunnysgt
If it's a Harley grip, No it won't freakin spin if you don't put glue on it. The newer bikes have a large tab on the left grip to fit into the slot on the switch housing. Never glued one never had to , glueing the grips is from way back when.... There may be some aftermarket grips that don't have that tab, in that case they usually come with their own adhesive.
Old Apr 10, 2014 | 03:04 PM
last12know's Avatar
last12know
i used the get a grips.. so i think your rite..
for what it's worth i really like the grips.. nice not having tacky hands at end of day..
