Hand grip install Question
Old Apr 11, 2014 | 06:02 AM
Mac daddy 103's Avatar
Mac daddy 103
Originally Posted by wander
get popsicle from freezer. Eat one 1/2 of popsicle. Squeeze the brake lever and create a gap between lever and housing on the brake reservoir end. Slide the popsicle stick into that gap so the brake lever isn't allowed to fully close upon release. Proceed with loosening the switch clamshell etc and installing the grip. After grip install and everything is buttoned back up squeeze brake lever, pull popsicle stick and release lever. Finish other 1/2 of popsicle before it completely melts. Tackle the right side grip if not already complete. Wash popsicle down with tasty cold beverage.
It's possible to break the brake light switch in the housing if the lever isn't partially squeezed thus the need for this step. Some grip kits come with a spacer but a popsicle stick works fine.
lol!!!
Old Apr 11, 2014 | 06:11 AM
Smash's Avatar
Smash
Originally Posted by Wander
Get Popsicle from freezer. Eat one 1/2 of Popsicle. squeeze the brake lever and create a gap between lever and housing on the brake reservoir end. Slide the Popsicle stick into that gap so the brake lever isn't allowed to fully close upon release. Proceed with loosening the switch clamshell etc and installing the grip. After grip install and everything is buttoned back up squeeze brake lever, pull Popsicle stick and release lever. Finish other 1/2 of Popsicle before it completely melts. Tackle the right side grip if not already complete. Wash Popsicle down with tasty cold beverage.
It's possible to break the brake light switch in the housing if the lever isn't partially squeezed thus the need for this step. Some grip kits come with a spacer but a Popsicle stick works fine.
Perfect. Now I know what the Popsicle stick is for.
Old Apr 11, 2014 | 11:19 AM
mutantsfornukes's Avatar
mutantsfornukes
Man, I really want a Popsicle now.
Good tip.
Old Apr 11, 2014 | 11:39 AM
Joe12RK's Avatar
Joe12RK
I'm going to have to change my grips so I can have a popsicle too...
Old Apr 11, 2014 | 01:19 PM
UltraNutZ's Avatar
UltraNutZ
Originally Posted by Mac daddy 103
Im installing new HD hand grips, Just want to know if the left side hand grip requires glue?. Thanks
the only product I'll ever buy from Kuryakyn is their ISO grips. I never use glue on the left grip because well.. my hand is never comfortable in one place for too long. So I leave it unglued to that I may roll it into the position that's comfortable for my hand at the time.
Old Apr 11, 2014 | 02:42 PM
Mac daddy 103
Hand grips done!!!! And no glue or Popsicle needed lol
Old Apr 11, 2014 | 03:05 PM
Gunnysgt's Avatar
Gunnysgt
As for the Popsicle stick, a zip tie stuck in there does the job as well. Glad the grips went well, I noticed the '14s have a much healthier brake light nubby, not near as prone to break like the older ones had.
Old Apr 11, 2014 | 03:37 PM
Xcrossbow's Avatar
Xcrossbow
Originally Posted by thebackupninja
Yep... I just replaced the grips on my '14 SGS and no adhesive required. Oh there were HD grips as well.
Same for me but with using Avon grips.
pomeara
Feb 1, 2014 09:03 AM
2007fxdc
Dec 10, 2009 09:01 PM
testifer
May 13, 2008 03:33 PM
grunt999
Feb 28, 2008 12:01 PM
Rhubarb
Apr 2, 2006 04:29 AM
