Synthetic M/C Oil
Old Apr 11, 2014 | 04:00 PM
07RoadHawg's Avatar
07RoadHawg
Originally Posted by bagman1
at operating temps you will get poor lubrication with 15 w at high stress areas Just my .02
15W vs 20W is not at operating temp but cold flow... That's where the 50 comes into play.
FWIW, on the Mobil 1 website the viscosity rating of the Mobil 1 15W-50 @ 100 Celsius is 18 and per the Castrol website the GTX 20W-50 is 18.09. At 40 degrees Celsius, the 15W-50 is 125 and the 20W-50 is 159.1
Thicker when cold, same at operating temp.
Old Apr 11, 2014 | 04:01 PM
bagman1's Avatar
bagman1
Originally Posted by Yukon42
Correct me if I'm wrong but I thought in multi-viscosity oils the oil will flow like a 15W at LOW temps and a 50W at HIGH temps. On that basis the 15-50 should flow just like a 20-50 at the operating temps of a Harley.
Youre right thanks for the correction, it probably wouldnt have an effect then.
Old Apr 11, 2014 | 04:07 PM
Uncle Paul's Avatar
Uncle Paul
Just a little something to throw into this oil post, for those whom have read this far.
Shell/Pennzoil (same company) has released a new oil made from pure natural gas.
It starts out clear and changes to a yellow/orange color when the additives are put in.
Claims that it is better to start out with a clear stock, than to start out with dirty oil that needs to be refined first.
Anyone have insight into this product?
Old Apr 11, 2014 | 05:00 PM
qtrracer's Avatar
qtrracer
Oil viscosity is a funny thing, here are some comparisons
Brad Penn Conventional
20/50 HI Perf 40c/159 100c/20
20/50 M/C 40c/167 100c/19.4
Valvoline Conventional
Straight 50VR1 40c/219 100c/20
multi 20/50VR1 40c/181 100c/20
m/c oil 20/50 40c/170 100c/20
Valvoline Syn oils
vr1 20/50 40c/147 100c/20
vr1 20/50NSL 40c/124 100c/17.3 NSL Stands for "not street legal"
m/c oil 40c/162 100/20
Red Line Syn M/C oils
20/50 40c/138 100c/18
20/60 40c/185 100c/23
Amsoil Syn M/C oils
20/50 40c/150 100c/20
60 40c/190 100c/23
As you can see the operating temp 100c(212 F) viscosity for all 50 weight rated oils seem to be pretty consistent at 20cSt. with some variance in 2 products, both synthetics. And the 2 60's are really the same viscosity. But on the 40c( 104 F) ratings there is a wide variance in viscosity at that temp.
EDIT when i did this i did it in columns and it posted like this:arghhhhhhh. sorry
Old Apr 12, 2014 | 10:29 AM
MNPGRider's Avatar
MNPGRider
Not to comment on a syn vs auto oil, but I have to disagree on the 15-50 vs 20-50, the reason being auto technology has gone to very tight bearing tolorances thats why you see 0 wt, 5 wt, 10 and 15w. But harleys are sloppy when it comes to tight tolorances and at operating temps you will get poor lubrication with 15 w at high stress areas Just my .02
If you check your owner's manual, you will find Harley recommends 10/40 at lower temps. Other posters have already addressed your post, but let me add:
Here in Minnesota, we often have COLD morning temps late into the spring and early in the fall (this morning was 42 degrees), but end up with 90 degree afternoons. I personally think the 15/50 oil is better than than a 20/50 for that reason. It will protect better at startup on cold mornings, but offer the same 50 wt protection in late afternoon.
Old Apr 12, 2014 | 10:49 AM
roadking2014's Avatar
roadking2014
some oils will form a gummy residue in the Catalyst if you have one in the head pipe.
Old Apr 12, 2014 | 11:02 AM
Veekness's Avatar
Veekness
...mostly Swiss cheese, but cheddar's okay too...
Old Apr 12, 2014 | 11:11 AM
grbrown's Avatar
grbrown
My owners manuals all say to use a diesel oil if MoCo stuff isn't available, designated CH-4, CI-4 and CJ-4. Both dyno and synth oils are available that meet those.
Old Apr 12, 2014 | 11:32 AM
Fast Aire's Avatar
Fast Aire
Former Sponsor
Just mixed it up.... 2 qts of 10-40 + 2 qts of 20-60 (Redline) = 4 qts of 15-50.
Well... in theory anyway.
Im going riding
Old Apr 12, 2014 | 12:57 PM
st john's Avatar
st john
Default Ok thank you
ZZZZZ ZZZZZ oh ok I agree.
