On my previous bike, I was going thru a battery once a year...then I would put it on the Tender when I wasn't riding it, and the last one lasted six years when I got rid of the bike...is still working on the same bike, new owner does the same drill. Yes, I know, riding it every week SHOULD not require use of the tender, but just like with many other electrical things, linear logic doesn't work too well...
I tender the bike after every ride.
Doesn't hurt anything. The Harley pig tail even has a red light that indicates if it needs to be tendered. I never see it.
To each his own, but why do you feel the need to do that?
I keep mine on the charger during the winter when it won't get started for several months but after the first ride of the season, no more battery tender and it is fine for the whole riding season. Been doing it this way for 30 years of riding without a problem.
I could understand if you go several months at a time between rides but definitely not needed if you ride weekly or even bi-weekly.
I'm also one who plugs my Tenders in after every ride. I'll be starting my nineth riding season on the original Battery in my '06. Although not needed for starting, I need a good battery in line for the Lucas electronic ignition on my Triumph T150 , which I purchased in '96. The battery bought new at that time is still in the bike and still holds enough voltage to fire the electronic ignition.
That's why we plug them in after every ride. Sulfation starts the moment the battery starts to discharge. Bikes with electronics that run even when shut down (clocks, alarms, etc.) are the most susceptible.
I have a small volt meter on my HD Smart Charger, and it is a little different than others. Even on a good hot battery, it will blink green for a few minutes as it outputs up to 14.2 volts (Like a vehicle charging system would) then gradually drops down to 12.4 - 12.8 volts as it goes to steady green.
Different makes will respond differently. Clip a meter on your charger, you will learn the particular characteristics.
YMMV.
I saw this post back in April, now that I am riding almost daily, I thought I would monitor the behavior of my Deltran Tender yellow/green lights - so I could respond based on experience. I plug in after every ride - almost immediately after the bike is parked. about 8-10 seconds and the flashing green light then about 30 seconds after that, the solid green. If I wait a while before plugging in the tender (let the bike cool down and wash it first). It will take a little longer to get to solid green - about 2-3 minutes. Battery is starting its second season.
Anyone ever have a problem with a false charge?? I had my bike plugged in for the last couple days and it gave me a green light. Then as soon as I took it off my bike wouldn't start. The starter wouldn't even turn over.
Thanks! That puts my mind at ease a little. I tried to start my bike this morning and it seemed so dead that the starter wouldn't even turn over. I was so confused because my tender gave me a solid green light. Hopefully thats the problem.
