Battery tender - green light
First, how big an alternator does the bike have ? My 2011 RGU has a 50 amp rotor/stator so every time I pull it in the garage, and plug in my battery tender, it almost immediately goes to full charge.
Second, I think it depends on your battery tender. I used to use a Deltran Tender Junior and have switched to a CTEK US3300 that can charge at 3.3 amps as opposed to the.75 amps of the junior.
My first dyna battery was 6 years old when I replaced it because I was going on a long trip. The one that is in the bike now is either 3 or 4 years old.
I am convinced that keeping your battery on a tender will make it last longer than without any help from a tender.
Both of the bikes go solid green within 1 minute after being placed on the maintainers.
Absolutely. The Tender is NOT a "battery condition" indicator.
It only acts on voltage alone.
However, as you found out, you CAN use the Tender as a general indicator of battery condition by noting when the battery comes up to an indicated full charge (13.8v) "faster than it used to".
When it's seen that the battery appears to come to full charge with the Tender faster than you were used to it doing, and it does so time after time, it might be time to load test the battery to judge it's true condition.
What's great about the Tender (or any good brand that does the same thing) is that it DOES extend the life of a battery to where it will maintain it's capacity much longer than without using the Tender.
However, battery chemistry isn't permanent, so I typically replace a battery after it's been in service for 5 years no matter how good it still works.
5 years on a battery is great economy of use no matter how you look at it.
Mine goes to blinking green within a couple a minutes but takes significantly longer to turn solid green.
I'd think after a ride it would be pretty close to fully charged and turn solid green right away?
