Oil temp gauge install problem
Old Apr 13, 2014 | 10:32 PM
Metal_Head75's Avatar
Metal_Head75
Default Oil temp gauge install problem
I recently installed the fairing mounted oil temp gauge, and it is not registering at all. The sending unit in properly installed in the pan, and the wiring routed up the left-side downtube into the fairing.
As the installation directions indicate, the harness female end is connected into the air temp gauge male connector, and the 3 prong connector attaches to the back of the gauge. Am I missing something? This seems pretty straight-forward and seems like a simple process. Please advise as to what I didnt do correctly. Thanks in advance
~ Gary
Attached Thumbnails Oil temp gauge install problem-20140405_164955.jpg   Oil temp gauge install problem-20140405_165054.jpg
Old Apr 13, 2014 | 10:42 PM
RAP's Avatar
RAP
How long have you run the motor after the install? It takes a little while for the gauge to register.
Old Apr 14, 2014 | 12:14 AM
NoCoLoco's Avatar
NoCoLoco
Don't expect it to start registering while idling in the garage, you gotta ride it around for a bit.
Old Apr 14, 2014 | 01:31 AM
crimson13's Avatar
crimson13
It takes a while to register , it took mine seem liked for ever to register.
Sent from my iPhone using IB AutoGroup
Old Apr 14, 2014 | 06:28 AM
Metal_Head75
Thanks for the responses, fellas...and it was ridden for about 60 miles yesterday.
Old Apr 14, 2014 | 06:52 AM
glcash's Avatar
glcash
I have the Dakota Digital oil temp gauge. Shows a reading soon as the bike kicks over. Shouldn't have to wait.
Old Apr 14, 2014 | 07:46 AM
EasTexUltra12's Avatar
EasTexUltra12
As others have said, it takes a few miles to start to register, and 15-20 to get completely hot. But 60 miles would be plenty far enough. All you can do is check all your connections. It is a simple system and the fix is probably simple too. If that doesn't work, trouble shoot. If it were me, I'd start at the sender. Pull the wiring off the sender and short the leads with something. Does it move now?
Good luck, post up what you find.
David
Old Apr 14, 2014 | 12:58 PM
lasvegasrick's Avatar
lasvegasrick
have a good look at the instr,i bet u forgot the ground at the gauge
Old Apr 14, 2014 | 07:41 PM
bill from tn's Avatar
bill from tn
There is a ground at the gauge? I thought it was just one plug to run everything and that uses the existing air temp harness.
Old Apr 15, 2014 | 07:22 AM
EasTexUltra12
There was no ground on the gauge on my 2012. Not sure about your bike. Sig says a 2002. They may be different. Was there a ground on the air temp gauge when you removed it?
David
