Wireing decompressors
looked at the 09 wiring diagram and there is no facility there, and no ACR facility at the ECM.
So this may require a change in ECM wpuld be required ( and would the thundermax be a better, less expensive way to go?)
but manual CR's would be fairly easy ( I see that a pair of JIMs are under $100)
Mike
Anyway, it was well worth it in my case. I had severe starter kick back thanks to the engine build from a 96 to a 103 by the former owner. He told me, ".... all Harleys kick back like that....". Idiot that I am and new to Harley I accepted that for a few days and then I came to my senses and had the compression releases installed, plus I had it built to a 107 since they had to go in there anyway. What a freaking relief to start the bike without people nearby saying, "Holy crap, that doesn't sound good!"
VR
http://www.harley-davidson.com/en_US...ts/-J04441.pdf
Anyway, it was well worth it in my case. I had severe starter kick back thanks to the engine build from a 96 to a 103 by the former owner. He told me, ".... all Harleys kick back like that....". Idiot that I am and new to Harley I accepted that for a few days and then I came to my senses and had the compression releases installed. What a freaking relief to start the bike without people nearby saying, "Holy crap, that doesn't sound good!"
VR
they allow a starting motor to spin a few times without compression to build up forward momentum, then the compression releases close, and the motor will then have fuel/air, spark, and compression and can start up.
the automatic CR ( ACR's) are used by H-D on the 103 motors.
and as discussed here, can be added to other models
the old Vincent Black Shadow had them controlled by a lever on the left bar
manual types are often just set into position by the rider and will close automatically
the twin cam motor has a light flywheel compared to earlier V twin motors, this allows the motor to build RPMS more quickly, but there are drawbacks, such as lower forward momentum, poorer low speed operation ( my '53 can ride at 600 rpms)
the twin cam is also typically higher compression than earlier motors
all this means that a motor trying to start can 'rebound" or reverse direction if the piston doesn;t have enough forward momentum to gets past Top Dead center ( TDC) on the compression stroke
mike
