herontheshadows...if your bike is a '10('09 california) or newer, it has a catalytic converter that is causing lots of the heat. the EPA requirements also makes it come from the factory with very lean air/fuel ratio and that also adds heat to the motor. address the converter and lean running conditions, and add the deflectors for a comfortable ride. your bike also has a heat management system that shuts down the rear cylinder when hot at idle to help lower engine heat...is yours activated? taking care of the heat issues with the motor and adding deflectors should keep you fairly comfortable--everyone does have a different heat tolerance level.
Give our Crotch Coolers a look, we have thousands of very happy customers and have many different way,s to customize them.. They also have a larger foot print than the others and they work very well. If you have any questions just give us a call.. We are a small leather shop and stand behind all of our products..
the cpt is a good way to go....reasonable cost too. I have the HD deflectors that came on the bike but put the crotch coolers right over the top of them. work for me.....give them a look. good folks, quick service too.
You need to recheck your signature ... I don't see it in your postings.
Hmmm weird.. I went into the User CP... under Edit Signature it still says 2014 FLHX- Big Blue Pearl... But even after saved it a second time it's not showing up on posts... Hmmm... Thanks for the heads up.
